Results 1 to 20 of 20
Thread: Problem with broken radiator hose
    LightningVP is offline Donating Member
    None
    Sep 2008
    Default Problem with broken radiator hose
    Hello, was looking at my engine today and I noticed a small leak from the hose just under the alternator, so I moved it a bit and it broke off. The HOSE is fine, but the pipe that comes out the engine has broken off.
    Has anyone had this happen before? or know of a way to fix this. I can't move my car as the radiator coolant just pours out that pipe and the car over heats...
    None
    Sep 2008
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    None
    Sep 2008
    Quote Originally Posted by greenacc View Post
    wow that sux, better work out what part it is and get a new one.
    I don't kow how to fix it...It's part of the motor, I was told the pipe (that is broken) just pushes in there and should come out with no problems...Am just hoping thats true...
    VP Calais
    Oct 2008
    Yeah mate, had a similar problem.
    Cars of this age accumilate problems with aging plastics and so on, time to go genuine and get new parts buddy!
    None
    Sep 2008
    Quote Originally Posted by JUZZIE87 View Post
    What exactly do I need? do I have to take off half the motor? or is it just a pipe that goes into the hole?
    VP Exec
    Jun 2005
    I think you will find that there is a 10mm head bolt that holds that part in place buried under the oil and dirt. Undo that and the remnant will pull staright out. You will need the replacement part and the 'O' ring seal that goes with it. Clean out the the hole it goes into, then insert the new part and refit the bolt. A wipe of silicon sealant (like Ultra Blue) may be needed if the hole in the block is corroded. The hose looks swollen and soft too, so good to replace that and the hose clamps at the same time.
    The cooling system will have to be bled too.
    None
    Sep 2008
    Quote Originally Posted by Cheap6 View Post
    Ok thanks, will have a look tomorrow at undoing it, and will be changing that pipe and clamps (as half the pipe is in the hose), but nothing in the cooling system anymore...all went out that pipe when I started car
    azz
    azz is offline azz
    vp wagon
    May 2008
    maryborough
    Default ive done this
    take off negitive terminal and remove the serpentine belt from the alternator (make sure you put it back on correcty) remove the two bolts holding the alternator and carefully lift the alternator enough so you have clear acesss to the water pipe (be super carefull with the alternator wires you may have to unplug one) there is a 10mm bolt holding the plastic joiner and most likely it will be broken off flush with the inlet mannifold so make a hook i bent a small screwdriver 90 degrees and use it to pull the broken bit out clean the hole with petrol and a scourer and use silicon on the new one. the bit is available from holden for about ten bucks. good luck
    None
    Sep 2008
    All fixed now, went to holden and asked them and the guy there said it's common, another guy had gone in earlier that day for the same thing, but it's just a bit of pipe that screws on...
    Thanks for the help
    For anyone interested, in case of future problems here is what it looks like:
    vp exec
    Dec 2006
    vaucluse, sydney
    had the same thing happen to my vp on southern cross drive in peak hour here in sydney... used a random breath test white tube to make a sleeve up to get me home! thank heavens for people who litter! cheers, pete
    None
    Sep 2008
    Quote Originally Posted by peter65 View Post
    Don't condone littering :| I'm a garbo
    But glad it's all fixed now
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    None
    Sep 2008
    Quote Originally Posted by pow3rslave View Post
    sorry to dig, but lightning did you have a thread number?
    thread number?
  15. #15
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by LightningVP View Post
    thread number?
    lol think he means part number
  16. #16
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    heh, yeah, chalk that up the the time on a saturday morning i posted it :P
  17. #17
    VN SPAK SII WAGON
    Mar 2005
    QLD
    Can anyone give me the name of this part or the part number?
    Mine shat itself today!
    Thanks
  18. #18
    VP Vacationer wagon
    Feb 2006
    The part in question is called a connector cool gm #92061300. Most importantly there is one on the back of the manifold also. It will also be brittle. If it comes apart in more than 1 piece, you have to remove the manifold to get to it. I removed my intake and just lifted it up and rotated it 90 degrees. I did this because I did not want to remove the throttle linkage. There is an o-ring that goes on it also.
  19. #19
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    thread tap the hole and screw a metal one in, thats what i did to the project vn... those plastic ones are a joke. otherwise buy like 3 of those plastic ones and have them ready in your tool box. its that common of a problem...
    dont sweat the petty... pet the sweaty...
  20. #20
    VN SPAK SII WAGON
    Mar 2005
    QLD
    Thanks guys, I had it fixed the same day it died a couple of weeks ago & replaced it with the metal type one.
    Cost was $20 which included the metal connector with O ring, new hose & clamps.
  1. radiator hose?
    By WhiteVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2007, 09:50 PM
  2. Gen III radiator hose collapse (i think)
    By Lish in forum General
    Last Post: 04-01-2006, 08:15 PM
  3. airlock in radiator hose
    Last Post: 03-01-2006, 02:06 PM
  4. Radiator Hose Clamps..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2005, 08:29 AM
  5. radiator hose
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 08:01 PM
