Results 1 to 10 of 10
Thread: VN Cliamte Control
    Feb 2008
    Default VN Cliamte Control
    Hey guys, ive added the vn calais climate control to my 89 vn s-pac, ive given you that information incase the problem i have got has something to do with the conversion.
    The climate contorl works fine, BUT, in winter, when i put the heater on, it switched itself off, even when the car warms off, no heat comes out, thats only when you have it on AUTO.
    its fine when you manually set it. But when its AUTO and you set it to something like 32 degrees, the A/C comes on and it blows out cool air, or like i said before, nothing at all...
    im going to change the unit soon. Im just doing some research first before the wreckers start ripping my arm and leg off for the climate control.
    thanks guys
    Ossama Bin Laden >>>>>>>>>>> Hide n' Seek Champ since 2001
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    When I was getting cold air in winter I pulled the control unit out and the plug was not all the way in. I stopped at that point and made sure it was in nice and tight. Put back together and she had hot air.
    So it was just the plug had not "clicked" into place whe I fiddled with the sterio.
    and 3 Dangerous non ABS VN's
    Feb 2008
    ill give that a try. problem is that if i do it manually, so i set 32 degrees and put the fan speed to wot ever speed and switch the A/C off, it comes out hot, it just doesnt do it on AUTO
    thanks though, so ill giv it a try
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by electro cruiser View Post
    Have you done a diag test?
    Look at Post #70 in here http://forums.justcommodores.com.au/...1-vn-v8-3.html
    Feb 2008
    yea but im not sure wot the numbers are.
    88GreenVN's Avatar
    Jun 2006
    If the test give you a 25 - this would indicate the sun sensor is kaput or the wire has come unplugged somehow.
    Feb 2008
    i did it and pressed the hotter button, showed a number, pressedit again and it showed 20, pressed it again a n showed a couple other numbers
    VP Exec
    Jun 2005
    There should be a water (engine cooling system) temperature sensor floating around in the heater core somewhere, maybe clipped to one of the heater pipes. If that isn't 'seeing' coolant temp. above a pre-programmed level, the heater won't work through the climate control. Sorry I can't be more specific than that atm.
    vp calais
    Oct 2008
    Hi can anyone help me
    i have a vp calais with climate control my air con works fine but it seems to cut out for too long about 15 to 20 sec. The air starts to get warm then it kick back in it doesent seem right to me.
    Feb 2008
    STOP TRYING TO STEAL MY THREAD!!!!!
    lol joking...seems like an electrical problem...maybe with the climate control head unit??
  1. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
  2. VN, VP, VQ Cliamte Control
    By Danniboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2008, 02:00 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
