Results 1 to 16 of 16
Thread: VP Adding a power antenna
    VP
    Oct 2008
    Default VP Adding a power antenna
    I just got a VP and am changing the car audio system from stock (adding a cd deck) and replacing the old manual antenna cause its broken and want a power antenna in there.
    Can I get some info.
    Does the stock have all the wiring for the power antenna installed?
    And what would I need other than antenna to be able to use a power antenna?
    Thanks
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    you might need the antennae up/down controls on the dash, not sure on that but my Calais does.
    The Black Beauty
    Hardstylin is offline Banned
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Well, the antenna automatically goes up when the radio is turned on, and down when the car is turned off, so I would assume the manual controls on the dash facia wouldn't be needed.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    True they may not be with some of the auto ones you can buy, but if you want it to run like a stock one off the pam then you will need the manual controls to set the hight of it.
    Reaper
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    You should consider getting a VS statesman window mounted one, then smoothing the 1/4 panel. Thats what i'm doing.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    In my vp ss the antena controls are in the cruise control assembly, you may need the same??
    STEALTHY™'s Avatar
    Jan 2005
    Yeah he will. VN/P are in the switchblock. VR/S are under the radio
    cheers sexy
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
  9. Default
    perhaps you could use it like this: wire up the antenna to power, and simply connect the remote or whatever wire it is to the headunit. then it should automatically go up/down depending on what state the radio is in. shouldn't need the manual controls on the dash.
    how the hell do you get to the aerial anyway. i need to replace mine but i'll probably just go manual, i don't care about it retracting.
    Quote Originally Posted by zai View Post
    I am not sutpid
    VP
    Oct 2008
    Quote Originally Posted by levymetal View Post
    Underneath the front passengers side wheel arch theirs a guard that's screwed on unscrew that and the aerial is accessible.
    And thanks for the tips guys.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yup, it's the black plastic wheel arch guard you have to pull back. Remove all the screws you can see, then wrestle it back with a bit of force. It'll move
    The 1972 HQ Kingswood
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Quote Originally Posted by Zuicider View Post
    u will need a power antenna module located above the ecu
    Zuicider is correct, without this module, you will just have an expensive manual antenna. I know on the VN, the wiring is already there in the loom, just plug and go. Also the dash buttons are needed, if you want to be able to raise/lower the antenna while listening to the radio.
    '76 HJ RB25DET Ute
    Feb 2007
    There is a white plug above the ECU that may or may not be connected to a antenna control module. There is 12V, 0V, (Up, Down from the buttons) and antenna remote from the head unit. Go and grab a 6 pin plug from narva (repco etc), suprisingly its a near perfect fit into the factory loom plug. Terminate your new antenna wires into your new plug and plug it bro. This will give you a very professional installation as you don't need to splice into the factory wiring. HTH
    94 holden belina sedan 5L V8
    Sep 2005
    Auckland, New Zealand
    i have a vp berlina with electric antenna, when i turn on the car it always goes up but sooner or later it desides it wants to go down, and i have to hold my finger on the 'up' button on the dash to keep it up, whats going on here?? does anybody know cheers
  15. #15
    1992 VQII Statesman
    Sep 2008
    i swapped the electric aerial in my VQ yesterday, the key thing i think is that the two yellow and white plugs next to the aerial that run into the car with the aerial cable are connected properly and that the aerial is earthed properly. i know that in VR/VS you can't adjust the aerial at all whilst the tape/cd player is on. also the aerial is set to retract independently of the driver. could be something there
    1992 VQII Statesman
    1991 VP Calais/ 1992 VP Calais
    1992 VPII Vacationer Wagon
  16. #16
    VP Berlina
    Dec 2009
    Quote Originally Posted by 3.8L of executive power!! View Post
    iv got that same problem i think it the module
  1. Power Antenna
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 04:03 PM
  2. Power Antenna
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2007, 10:42 AM
  3. Adding Power to speakers
    By Pav in forum Car Audio
    Last Post: 22-03-2007, 08:21 PM
  4. Power Antenna
    By VnWag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2006, 08:09 AM
  5. Power Antenna Help Please?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2006, 05:52 PM
