Results 1 to 8 of 8
Thread: engine warning and alt lights
    88 VN 5spd 3.8
    Apr 2007
    Corio,Victoria (Geehole)
    Default engine warning and alt lights
    ok guys please dont rip me a new 1 for starting a new thread i've searched and searched but still cant figure it out........
    recently removed engine to replace sump after hooking it all back up and starting
    im getting both warning lights and my alt light comes on when key is off and out
    ive checked codes and its comin up code 12 all ok
    ive gone over looking for any shorts or loose wires only thing i can find is alt plug is missin its little clip....
    any suggestions would be appreciated
    HSV-VN-DMG 90 No.18 of 50
    Oct 2008
    Gold Coast
    Talking
    Gday Mate, I have some simple things to do which you may have already done. Remolve the ENG COMP fusible link from the fusible link housing under the bonnet near the relays for 10 seconds and run the motor at 3000rpm for 10 seconds and check the hose for cracks which run to the MAP sensor. Hope this helps.
    88 VN 5spd 3.8
    Apr 2007
    cheers mate, iv already reset ecu but i'll check that hose also can any 1 tell me what the
    red warning light with ! in the middle is a actually a warning for also what damage would be caused by having a injector plug on the alt and vice versa
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    the red warning light with the ! in the middle is brakes i think
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Make sure the reg wire from the alternator is connected properly to the pos on the battery.
    88 VN 5spd 3.8
    Apr 2007
    so hopfully the light will go out after i replace mi right hand caliper(brokenBleedervalve)'
    and bleed the system
    vt commador
    Nov 2008
    Mate the ! is your park brake light i would check the button under your hand peice and make sure it is wired up or maybe faulty
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by NATHAN WATSON View Post
    umm no the "!" symbol is the breaks and the "(P)" symbol is the park break
  1. ABS, Trac Control and Engine Warning Lights
    By aborchy in forum Electrical Wiring / Questions
    Last Post: 19-12-2007, 09:49 AM
  2. All warning lights come up
    By eeugene in forum Electrical Wiring / Questions
    Last Post: 19-03-2007, 09:21 PM
  3. VU Warning lights.
    By TJK-R in forum Electrical Wiring / Questions
    Last Post: 04-09-2006, 04:59 PM
  4. warning lights
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2006, 01:30 PM
  5. Warning Lights
    By redvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2005, 12:24 PM
