Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Useless brakes
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Useless brakes
    hi there
    i know that VNs have the worst brakes on the planet, but mine are exceptionally bad.
    i got new rotors and pads on the front and they didnt seem to make any difference.
    if i try to do a burnout for example, brake push down as hard as i can the car just rolls forwards reluctantly.
    could it be that my master brake cylinder is rooted? im thinking about putting twin pot calipers from a SS on the front with the 290mm rotors.
    apparently you need a 1" bore to use these brakes, and according to my gregories manual all VNs have the 1" bore, is this true and how could i tell without pulling it off?
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    u need the VT brake upgrade
    burnouts aye, hopefully on a track
    The Black Beauty
    VN Executive
    Apr 2007
    lol yeah always on the track or my driveway.
    VT upgrade requires hub adapters which look dodgy, and they cost like $1500 for some vague description of what your getting
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    vn v6 had 15/16", v8 had 1"
    most of them have 15/16 or 1 stamped on the front of the master cylinder.
    and something that i think everyone should do, is a stronger bracket that bolts to the front of the master cylinder.
    get someone to push the pedal to the floor, while you watch the master cylinder from the side. with firewall flex, mine moved around 4mm. they say 5mm of movement equates to 25mm of lost pedal travel.
    if youve got a hacksaw, hammer, vice and a drill, you can make your own bracket for the price of a small piece of 3mm aluminum.
    http://lowagz.sytes.net/pictures/brakes/IMAGE_00042.jpg
    http://lowagz.sytes.net/pictures/brakes/IMAGE_00043.jpg
    http://lowagz.sytes.net/pictures/brakes/IMAGE_00044.jpg
    VN Executive
    Apr 2007
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    if you are pushing the pedal hard to the floor to light the rear bags thats half your drama as you are starting to pull on the rear brakes too
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I think you need to bleed your brakes properly. Vn's are far from the worst brakes out there ever driven a car with 4 wheel drums?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Power booster can be knackered too.
    and 3 Dangerous non ABS VN's
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    +1 for Hawkhawk, iv got a stronger one in mine to try and take some of that flex away. Its slightly disturbing how much flex you get.
    And possibly you have a booster thats dying maybe. I'd be doing somthing about them soon, the brakes suck as they are let alone not working properly
    Reaper
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    did putting the stronger bracket on help with breaking? like was it noticeable??
    cheers
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by jas98 View Post
    cheers
    was a bit hard to tell for me, as i swapped to v8 rotors, calipers and master cylinder and the bracket all around the same time.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    can you hear a sucking sound when oyu apply the brakes? if you put your foot on the brake and start the car does the pedal sink? non/ a little/ a lot? if you have your foot on the brake and switch the engine off does the pedal come up or stay where it is?
    hakhawk. nice job on the bracket. working on something similar for mine at the mo
    Body by Holden, Soul by Brock
    the Legend will live forever
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Quote Originally Posted by Anthraxnz View Post
    They cost less than $500 a pair and many people use them without any dramas. Try bleeding the brakes as mentioned first. It probly hasnt been done for years.
  15. #15
    VN Executive
    Apr 2007
    na i've done the fluid.
    what needs to be done for VT calipers? they bolt onto the standard mounts on a VN but what sort of rotors? will the VN V8 ones do?
  16. #16
    VrWagz1's Avatar
    May 2008
    wollongong
    vt rotors^^^
    Reaper
  17. #17
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I just got slotted standard size front rotors, to be honest they work just fine for me. That's what I'd be looking at doing first if I were you.. don't expect miracles, but it's definitely an improvement. Plus you're increasing the front bias (effectively) so burnouts become that much easier if you're that way inclined..
    Sam
    WTB: mulberry VN interior parts
  18. #18
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Dan355 View Post
    thats in aussie, once you land em here in NZ with the difference in exchange rates and tax's and duties a AU$700-800 kit easily becomes NZ$1300-1500
    try these guys http://www.twobros.co.nz/catalog/pro...roducts_id=161 (hubs only) so would still need to find new rotors, calipers/pads and new brake lines. they are about the cheapest i've seen in NZ
  19. #19
    VN Executive
    Apr 2007
    are billet hubs dodgy? or are they just as good as putting the proper rotors on; strength wise?
  20. #20
    VN Executive
    Apr 2007
    Code:
    Braided Hoses	208.89	http://www.twobros.co.nz/catalog/product_info.php?cPath=3_95&products_id=159
    2nd Hand VT Calipers	146.67	http://www.twobros.co.nz/catalog/product_info.php?cPath=3_99&products_id=39
    Hub Adaptors	440	http://www.twobros.co.nz/catalog/product_info.php?cPath=3_122&products_id=161
    Master Brake Cylinder	330.7	http://www.twobros.co.nz/catalog/product_info.php?cPath=3_96&products_id=42
    VT Brake Rotors	70
    Total: $1196
  21. #21
    VN Executive
    Apr 2007
    i now think i have a leaking Master Cylinder, when i pump the pedal and hold it down then turn the engine on the pedal drops, then continues to fall slowly.
    my manual said this could be a problem with the Hydraulic system
  22. #22
    Dan355's Avatar
    May 2006
    Quote Originally Posted by immortality View Post
    try these guys Two Brothers Performance Parts Ltd (hubs only) so would still need to find new rotors, calipers/pads and new brake lines. they are about the cheapest i've seen in NZ
    Fark... Didnt realise that!
  23. #23
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    na mate thats ur booster i belive thats loosing pressure. Is it getting really hard to push the pedal as well? Any hissing noise? If u have these then its ur booster, not too hard to change as ive just done mine myself not long ago.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
  24. #24
    Apr 2006
    Auckland NZ
    if the pedal drops when you start the engine then the booster is fuctioning. if the pedal pushes your foot up when you stop the engine then you have a problem with the one way valve on the booster.
    if the pedal drops and then keeps going down you either have a leak somewhere or your MC is kaput.
    last night my booster failed completly. started braking going down a hill and the pedal was almost completly solid. could hear lots of sucking noise, changes when you apply the pedal. when i switched the engine off the pedal pushed back up under my foot. very odd sensation. think i'm up for a new booster. think i'll fit a late model one so that when i upgrade to VT brakes it's all sorted.
    don't forget to add GST to those prices for the brake parts.
    i figure i only need the hubs and lines. i can get the other stuff elswhere cheaper
  25. #25
    VN Executive
    Apr 2007
    i pulled the valve off and theres suction, i blew into the manifold side and it didnt leak or allow air to pass through.
    the pedal does come up when i turn the engine off, so is the valve stuffed and my mouth doesnt have enough PSI to test the valve with?
  1. useless button
    By commy kid 92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2008, 11:07 PM
  2. cops are useless!!!!
    By Astranomical in forum The Pub
    Last Post: 03-05-2008, 07:52 AM
  3. want to know something useless?
    By Arth in forum The Pub
    Last Post: 14-04-2006, 08:51 PM
  4. Brakes somewhat useless
    By Pistol in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 03:37 PM
  5. Useless Information....
    By rattattack1313 in forum Jokes/Humour
    Last Post: 17-10-2005, 07:17 PM
