Results 1 to 7 of 7
Thread: air con VP
    vp calais
    Oct 2008
    Default air con VP
    Can anyone help me
    i have a vp calais with climate control my air con works fine but it seems to cut out for too long about 15 to 20 sec. The air starts to get warm then it kick back in it doesent seem right to me
    vp calais
    Oct 2008
    has anyone got any ideas can throw my way, I have changed the sun sensor and it's not the problem. Now I am going to change the climate control unit. The dignostics chesk says that the sensor are fine. Stage 3 shows 31 vent and console is it suppose to show. Please I need some help to fix this.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Perhaps it might be just a bit low on refrigerant or the pressure switch is faulty. When you first turn on the A/C does it get cold quickly or does it take a while?
    MY RIDE
    vp calais
    Oct 2008
    it takes awhile and refrigerant has been looked at and is fine anso is the pressure switch
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by vpcalaishsv View Post
    Is the compressor actually cycling on and off with the temperature fluctuation?
    If so, there are two possibilities. Either the low/high pressure switch is being activated or the climate control is deciding to cycle it.
    I would establish which by monitoring the voltage before and after the pressure switch. You could connect leds to these and have them in the cabin to see what happens when you are driving(if the problem doesnt appear at standstill)
    Voltage disappearing before the pressure switch indicates climate control/electronics/sensor problems, after the pressure switch indicates charge problem or switch problem.
    vp calais
    Oct 2008
    i have looked at all of that and it work like it should.Now i have found there are 2 pipes that go into the dash. the biger 1 from the accumulator witch is not as cold as the 1 coming from the evaporator.
