Can anyone help ?? I cant find the engine number on my 5.0L injected motor...my mate said it should be on the side of the block on the right, but where all I can see is extractors HEEEEEELP PLEEEEEEASE
In line with the oil level tube
and 3 Dangerous non ABS VN's
I was told near the number 1 spark plug I still cant find the bugger thanks for the reply ..... if anyone has pics that would help![]()
It's on the right hand side of the block as you look at it from the front of the car, above the No 1 spark plug. It is stamped on the block's top machined surface adjacent to the head. It will start with two letters and then 6 numbers (ie. VT 123456). If the block has been machined due to a rebuild, it's quite possible the number has been machined off (very common). If it's not there, you will require a forensic scientific method in order to reveal it (don't try this yourself unless you know what you're doing cause you only get one go).
