Results 1 to 8 of 8
Thread: Changing Throttle bodies
    HSV-VN-DMG 90 No.18 of 50
    Oct 2008
    Gold Coast
    Default Changing Throttle bodies
    I changed from the standard VN V6 throttle body of 60mm to a 70mm throttle body, but the Engine Warning Lamp stays on. The car runs well. I removed the ENG COMP fuse and the Warning Lamp went off for 2 seconds and came back on when the car was started. Only thing is at the end of the butterfly shaft where the Throttle Position sensor goes it is of a different size from the standard (smaller) could this be a problem. Please Help.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    That could be it... change back to the standard throttle body and see if that fixes it. If so, then you know the problem is in the new TB. If it doesn't fix it, then you know something's broken
    70mm throttle body won't change anything on the car anyway, so there's no harm in putting the 60mm back on and keeping it that way
    The 1972 HQ Kingswood
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Are there any benefits to changing TB size in a stocko six? If greenfoam reads here I'd love to know a bit about the relationship between TB sizes and retuning possibilities..
    WTB: mulberry VN interior parts
    Morton's Avatar
    May 2006
    No benefits at all. The throttle elbow between the throttle body and the inlet manifold is less than 70mm in diameter.
    VP Exec
    Jun 2005
    Agreed, no benefits to maximum power (the T'body isn't a major restriction at near standard power levels). It will change the relationship between airflow and pedal position so it will feel better (at part throttle positions).
    The check engine light is probably due to a throttle position sensor fault code, because the TPS is not being rotated by the smaller end of the throttle shaft. There should be a small adaptor that fits on the end of the throttle shaft to drive the TPS. I'm not sure if you can buy that separately though.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    i noticed a big difference when i chucked a yella terra 70mm on but even more difference when i go the die grinder onto the elbow
    VP Executive R-spec
    Jan 2005
    On the V6 there is more than enough in the standard throttle body, the throttle body flows something like 500cfm, you would need a really mean V6 to get anywhere near needing that much air. Everyone thinks they are going faster because with a 70mm you get to 1/2 throttle at 1/4 throttle but all you are doing is the same thing as pushing twice as far on the accelerator as you were before
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Knew that Jason I'm not retarded
    Was just wondering, my VN is quite sluggy (VTish) after my uber-lean tune, so thought maybe a bigger TB would wake her up a bit
  1. throttle bodies
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2006, 11:16 PM
  2. throttle bodies i know sfa
    By calais_304 in forum General
    Last Post: 08-08-2006, 06:30 PM
  3. Throttle bodies
    By big_c_43 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2006, 07:56 PM
  4. S/C or 402 or 8 Throttle Bodies?
    By slowr8 in forum Projects
    Last Post: 29-05-2006, 11:06 PM
  5. throttle bodies
    By doggie458 in forum LSx Development and Modification
    Last Post: 14-10-2005, 09:29 AM
