Results 1 to 18 of 18
Thread: Need mechanics advice
    VN Berlina 2L
    Oct 2008
    Default Need mechanics advice
    Hi
    Are there any mechanics that go through this forum?? I need some advice.
    I have a VN Commodore with a 4 cylinder 2 litre Opel/GM 20SEH Family 2 engine, when I reverse the car it works fine but when I try to drive from stand still the car throws you back and forward. After the car has gotten going then I can drive it normally, the engine revs fine when in neutral.
    It seems that the engine wants to stall when in low rpm and the clutch is slowly engaging. Putting more throttle on it causes more jerking. Its almost like the engine power is surging, it gets a surge of power then it looses power then gets another surge and causing rocking motion.
    I have checked the fuel intake system and I have checked the air intake. I have checked the ignition leads, on cylinder 1, 3, 4 the leads are around 8.8 - 9.0 KiloOhms, the 2nd cylinder is reading 18 KiloOhms. I have replaced the 2nd cylinder lead with another lead but still the same problem (The new lead is 12.8 KiloOhms). I have tested the ignition coil by plugging in a spark plug instead of the one on the engine, I then grounded it and watched the spark, it was a orange spark. I understand that it should be bright blue. So could my ignition coil be out?? Its pretty old, I dont think its been replaced since it was made. Also the distributor looks like it could use a clean. Would that be causing my problems??
    I have checked the fuel filter, thats fine. Could it just be an old ignition system??
    Is it possible that low cylinder compression could be causing this??
    Anything else I could try??
    Thanks
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    not alot here no much about the 4 cyls as we didnt get them in Aus
    The Black Beauty
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    VN Berlina 2L
    Oct 2008
    Quote Originally Posted by Ozzie View Post
    Check to see if your coils not loose!
    Common problem with those simptoms
    My coils not loose?? I have only one ignition coil and its held on by a bracket. I have checked all the connections throughout the ignition system.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by KnobMuffin View Post
    If its a single coil then you will have a seperate dizzy...
    Is it an electronic distributer? If so it may need replacing.
    If its the old style distributer then you may need to clean the rotor.
    VN Berlina 2L
    Oct 2008
    Update: I think its the TPS sensor, I tested it today, there is continuity when the throttle is closed but when I open it (past the clicking point) there is no resistance and hence a open circuit. So I think my TPS is buggered.
    VN Berlina 2L
    Oct 2008
    Its not the TPS sensor, I ended up taking it apart to find its a very primitive sensor. Any other ideas??
    vn calais, vs clubsport #137
    Jun 2005
    it would have to be pretty low compression to cause this, i would perhaps be looking at the rotor button in the distributor.
    '76 HJ RB25DET Ute
    Feb 2007
    Just a thought mate, your looking thoroughly through the engine components, yet you stated in your OP that when you drive in reverse the car is fine, yet when you drive off on Drive its f#$ked. The penny dropped...???
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    4 cyl commodore = petrol prices as the jap cars have.
    You could try putting the car into limp mode and taking it for a drive if it doesn't surge then maybe electrical/sensor problem
    VN Berlina 2L
    Oct 2008
    After pulling sensor and what not apart, I found a small split in the hose between the air flow sensor and throttle body, the split was hidden because it was underneath and so I could not see it. So I tapped it up and now its working fine!! Just a simple split!!
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    check for smoke under bonnet, i hear the startfires are good at external ignition!
    in all honostly i dont know if they use coils but its a ignition related problem, check your engine ground/ if it has coils your coil pack grounding straps... reason neutral will be fine is its not under any load, stick it under load and it wont beable zap enough current through with the current grounding. maybe replace the grounding strap with a new one, i did this on my supra and it fixed my issue..
  15. #15
    VN Berlina 2L
    Oct 2008
    I tested my coil by running a plug grounded to top of the engine housing and its pretty weak, so I am going to replace it with a Bosch GT40 coil, hopefully that will bring some more life into my engine.
  16. #16
    vt 3.8 ltz
    Aug 2008
    please any one can help in my ride vt v6 after cranking after the engine is started after 2 sec. i hear some noise from the engine dont kno wat is it second thing while travelling suddenly engine stops and dosent starts then after about half hour it starts normally keeps on doing this when engine stops while cranking i tried pluging out the plug lead from the coils one from each no spark while cranking any solutions i live in uae very very few mechinics to understand so please do help me
  17. #17
    vt 3.8 ltz
    Aug 2008
  18. #18
    vr stroker v6
    Jan 2009
    townsville qld
    put a v6 in it
  1. Any mechanics out there? Help.....please!
    By redtamada in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2008, 03:09 AM
  2. Rip off mechanics
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2006, 01:00 PM
  3. Is There Any Mechanics on here
    By Phoenix21 in forum General
    Last Post: 14-05-2006, 08:28 PM
  4. Mechanics
    By rebel in forum General
    Last Post: 22-02-2004, 07:40 PM
