Results 1 to 14 of 14
Thread: VN Stoping and running rough
    2001_VXSS's Avatar
    2001_VXSS is offline keepin' it real
    VR Berlina Series II
    Sep 2008
    Default VN Stoping and running rough
    I have a 88" VN. last month or sometimes would just stop while i am driving completely die nothing. also the ECU wiring that runs throught the fire wall on the passenger side has been attacked by previous owner and has just grazed the cover off of 4wires i have wrapped the wires singlely and im pretty sure that it is not the problem.
    ok here is what the car does...
    if i drive the car calm it will run fine and have a 5% chance of stopping or running rough.
    but on the other hand if u give it to her she will run fine then after a lil while when i go to stop at either lights on a corner, like completely stop she will either shut down without notice or running rought (anywhere from 300 to 600RPM) then if u give her some fuel she dies. then wont start again for a while. its like she has to sit for about 5-10mins to reset or something before you can start her.
    im going to get some new spark plugs and maybe some leads tomorrow to see if that changes anything..
    does anyone have any idea's of what could be causing the problem??
    My Write-Off
    http://forums.justcommodores.com.au/...t-berlina.html
    Originally Posted by hotred View Post
    Will, obviously our checkers game was disrupting the public lol.
    Posted by DVSV8
    we were playing hoon checkers! did you here all V8's screaming every move!
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The CAS, coils & DFI are the main culprits for stalling and running badly.
    The CAS is the cheapest thing to chage. Sometimes you can swap a coil/DFI unit with a mate to see if that is the problem.
    Other times it can be the ECU. Are you getting any error codes out of the computer?
    and 3 Dangerous non ABS VN's
    2001_VXSS's Avatar
    Sep 2008
    Quote Originally Posted by ashbox View Post
    ign module, coil pack.
    so you have had this problem or know someone who has? cos atm im getting really P****D off with it.. cos it stops when i dont want it to like at roundabout with cars everywhere. where would i be able to get a module from? (you do mean the module under the coil pack?) how much would they be?
    well im replacing spark plugs tomorrow if that dont change anything ill see if i can get my hands on another module.
    cheers
    My Write-Off
    Posted by DVSV8
    2001_VXSS's Avatar
    Sep 2008
    Quote Originally Posted by 88GreenVN View Post
    nope, no error codes. that what got me stumped.. and annoying me so MUCH!!!! if i got a CAS from UPULLIT how can i tell if its alrite or stuffed? is there any way or just a game of chance? cos i have asked round and new CAS is about $60 ohwell i just want it fixed
    cheers
    My Write-Off
    Posted by DVSV8
    88GreenVN's Avatar
    Jun 2006
    Plugs wont change the stalling. Coils & DFI S/H from the wreckers will set you back about $90 and take about 30 mins to fit tops.
    2001_VXSS's Avatar
    Sep 2008
    so whole coil pack with module as well? and DFI S/H (btw what is DFI S/H stand for, having mental black) cheers might go pick one up tomorrow and see if it changes anything. hopefully it does
    My Write-Off
    Posted by DVSV8
    88GreenVN's Avatar
    Jun 2006
    second hand......
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    yeah happened to me with my 5 litre, ign module **** itself and took the coild pack with it, might be a diff story with yours
    Chev badges are an instant fail
    2001_VXSS's Avatar
    Sep 2008
    well i changed spark plugs and noticed that one of the spark plug top (the white bit on the spark plugs) was broken half missing. so replaced them. took the car out for a run gave it heaps and it not giving me any trouble.
    will advise about any problems hopefully not. (touch wood)
    cheers for all the advice.
    My Write-Off
    Posted by DVSV8
    2001_VXSS's Avatar
    Sep 2008
    car completely stopped yestoday.. fuel pump finally kicked it self in.. its F****D!!!! so gettin new one put in today and she will be good to go cruising and CAR SHOW!!
    My Write-Off
    Posted by DVSV8
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    just jumped on this thread and was about to tell you ive had the same problem previously and it was becuase the fuel pump was getting blocked partially. Mainly did it when it was udner 1/4 tank full. if i went uphill for a period of time or repetatively went around a roundabout it wud stall and id kick the accelerator, and it wud push thru then slowly die etc. Only cure was to let it sit for a few mins, and try and start again once the fuel tank had settled. GET YOUR TANK CLEANED OUT SO ALL THE CRAP DOESNT BLOCK YOUR FLITER. Its the main reason its happening
    wow i feel kinda useful
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    2001_VXSS's Avatar
    Sep 2008
    Quote Originally Posted by Vn_Manual08 View Post
    cheers. yeah mind did excatly that.. haha weird. nah it diffently fuel pump cos it doesnt prime at all.. and tank will be check while mechanic changing pump..
    cheers
    My Write-Off
    Posted by DVSV8
    social's Avatar
    Nov 2008
    South Aus
    no probs man, first day on forums and im showin some love haha its a pity the vn petrol tanks dont have a tank plug so you can empty out the fuel easily, only real way is to disconnect the fuel pump then unbolt the tank and tip it out
  1. vt rough running
    By Jaybee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:37 PM
  2. running rough
    By braks in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2007, 01:09 AM
  3. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  4. VN running rough
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 08:26 AM
  5. running rough
    By Rumbl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2005, 05:24 PM
