Results 1 to 3 of 3
Thread: VN engine error code 15
    VN Executive
    Nov 2008
    Default VN engine error code 15
    Hi all,
    My VN was running rough when cold and the engine light was on. It ran Ok when at operating temp.
    I checked the error codes an a error 15 was reported. I replaced the Engine Coolant Temp (ECT) senor and checked the voltage supplied to it which was 5v
    After resetting the errors in the computer and starting the engine the I allowed the idle to reset itself and turned the engine off.
    When I turned on the ignition the engine cooling fan came on and after starting the engine the error light came on again. I checked to make sure the computer was not in diag mode.
    I checked the error code again an have received the same code again.
    I have checked the new sensor and its resistance decreases with heat and I have checked the connections to make sure they are clean and tight.
    Please help.
    VN Executive
    Nov 2008
    Jun 2006
    ya the ECU can be a prick ... it can be last thing you think of replacing ..
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
LinkBacks (?)
  1. Engine light on, but no error code!
    By Wesleyrpg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2008, 12:18 PM
  2. Error Code 44 and 76 - how do i fix it
    By the_cookster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2008, 07:31 AM
  3. Error Code 44 / 64 92
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 08:17 PM
  4. Error code 46 on VR
    By Equipe VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2007, 09:10 AM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
