Hey all
Ok i have just finished the swap which was pretty simple. I had to scrape off the blue paint at the back of the copper board so the gauges made contact with them, other then that everything works.
However..
The only issue i have is that even though i did not remove the speedo needle, it sits jus tbelow the first notch next to 0. I had a look on ebay at clusters and most if not all have them sitting pretty much exactly on the first notch or just above.
I was wondering if this is normal? Having it sit below the first notch.. its only a bee's d*** below the notch, just enough to see about 1mm of black if tha tmakes sense lol
Thanks for reading![]()
