Hey, gotta change the alternator in the step-dads car tomorrow (well, actually today) I know how to get the alternator off, just not sure how to lossen the belt...Thank for any help
I did mine, when you loosen all the bolts the alternator tips in a bit and lets slack onto the belt. If its a 6 though, not sure as never done one but cant imagine it to be to hard, there must be a tensioner pulley in there somwhere you can play with. And remember to check the wire around the lug is not burt if its the 6 too.
what kind of car? v6? if its a VN-VR engine, there is a tensioner pulley next to the alternator. stick a 19mm spanner i think on it and twist it to loosen the belt
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Ahhh, thanks guysyeah is a standard V6
Musn't be that engine...there is not tensioner puller...it's a VN/VP motor...not VR, hence why it's in the VN/VP section...
Ahhh worked it out![]()
...bit of trivia here... you can use the wheel brace on the tensioner nut too as the nut is (close to) the same size as the wheel nuts... i found that out the hard way on the side of the freeway...
pete
