disc brakes
vpdood
37
west aussie
92 vp berlina
i got some mags for my car but they are made for a vs and the front hub is different.....my dust cap on the front wheel gets in the way of the center caps for the mags sooo......
i'm curious to weather the vr-vs front brake discs and assembeley will fit a 92 vp?? has anyone done or heard of this before??
SlowVac
Owner of a SlowVactioner
41
VN SII
The answer would be no(That I know of :confused: ). wouldn't be cheaper to look at VT setup? Take a pic of the rim because it's the frist time i heard of this.
AirStrike
91' VN SS
Go the VT setup. Then you will get the corect hubs so they sit right.
Look in the online shop or email Tony [email protected]
AirStrike :air:
mr-spares
56
Croydon Victoria Australia.
HRT UTE 355 supercharged
Brakes
Another option is to replace your caps with an early type cap possibly.
I can sell you a VT upgrade kit but it may not make any difference to the caps at all. This kit is $470
The other option is to convert your VP to a VR / VS front end, the only drama is the top hat needs to be modified with a new bearing welded in to take the bigger struts. This option will be around $900.
Tony
VTSSDUDE
NSW, Australia
VT SS 5.7L Commodore.
You sure these are a good brand of wheels?
Never heard of that sort of problem before. Unless these tyres were specially made for VR/VS hubs I can't see them not fitting on any other commodore.
Cheers,
Jim :cool:
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
I ran into this problem with my other car.... a vp with vt brake conversion and the vs factory mag wheels just don't fit because of the hub so I couldn't fit them.
