Results 1 to 8 of 8
Thread: VN S1 Auto wont rev past 3500 in gear, 4500 in neutral
    VN1 Auto V6
    Dec 2004
    Default VN S1 Auto wont rev past 3500 in gear, 4500 in neutral
    Hey all
    I have been having issues having to start the vn 2-3 times before it actually starts and doesnt stall.. Once it starts you can smell petrol which would indicate to me that the fuel is getting in fine but not firing.
    So i bought some el-cheapo supercheap plugs and good lord i felt a huge improvement down low. It was as if before there was something holding back the power.. now its fine.
    HOWEVER
    After testing the low throttle response i was over the moon :P then i though what the hell, floor it and see how she goes.. But it would get to 3000rpm then just make lots of noise but only vveerryy slowly gain revs. It was getting to the point where it would change gear but it would stay at the same revs.
    I though ok this is a kickdown thing.. so i tried revving in neutral and could only get to 4500rpm and it would do the exact same thing it was doing in drive.
    I am reall yhoping its a blocked cat? lol Since the old plugs were shagged, they wernt burning the fuel how they should so there was not as much exhaust gas as there is now. Now they are working how they should, the cat is causing a restriction and not letting it rev anymore?
    The sound is as if its a slipping clutch.. the sound of the engine doesnt change, it doesnt want to stall just stays at the same revs only sllliigghhhttlllyyy moving up and up.
    What do you guys think?
    **PS!!** I forgot to mention that ever since i have owned the car i always get error code 13- O2 Sensor. I have replaced them twice (2nd hands) and 1 brand newy and STILL get an engine light on during first 30 secs of driving which then goes away. Always error 13.
    **PSS!!** Tomorrow i am going to remove the cat and install new leads see if that makes any difference..
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    if in doubt unbolt the cataylic converter and start it up, does your manifold glow red and can you feel compression out the exhaust??
    VN1 Auto V6
    Dec 2004
    Well i unbolted the cat today, and to my dismay it was perfect lol Which is good in a way i suppose but still i was really hoping that was all it was.
    Would improperly adjusted spark plugs give this result?? As i installed the new sparkies straight from the packet as my feeler gauges fell apart down the back of the bench.. the ones i did find were all covered in rust so i had no idea what size they were, and even if i did find the right one they wouldnt be accurate now.. grrrr
    the plugs i used were the bosh super cheap 26-6 i think they were called..
    HR9DCY+ 1.5mm is whats on the packet. They are the right sparkies but not sure if they are fine to use out of the packet?
    SHould i try a new set of leads and see how that goes??
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    the plugs should be fine out of the packet. never had to adjust any myself
    VN1 Auto V6
    Dec 2004
    phew :P That rules that out then thanks
    Ohh and to just update i have replaced:
    Resetted the ecu
    NEW fuel pump
    NEW fuel filter
    2nd hand injectors
    2nd hand regulator
    NEW spark plugs
    Cleaned the IACV
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    seems weird.. a friend of mine had the same issue in his vp wagon.. it would get to 3.5 then slowly go up.
    it ended up being a shot ground somehwere behind the dash. i can find out exactly what it was if your interested.
    VN1 Auto V6
    Dec 2004
    Hmm well it SEEMS to be fixed all of a sudden?? I tried revving it in neutral and it revved right up to redline (which i didnt want it to go, as i was thinking it would stop like it usually does lol). I havent tried it in gear yet as im not dumb enough to floor it during the day when there are more people on the road. I do my testing in an industrial area where nobody is around.
    However i am still having the hard starting problem.. its nto a fuel issue as it floods and you can smell petrol when it starts after the 3rd consecutive time.
    As soon as i turn the key it would usually start, very fast. Now it will fire for a split second (when it would normally start) then stop as if teh first few spark plugs fire and the rest give up.
    So i will just buy new leads and eithr a second hand coilpack/dfi from a S2 and up V6 OR save some money and just buy brand new bosch or msd coils so i KNOW that there is nothign wrong ignition wise.
    Only thing i am worried about is the car eventually not starting at all before i have time to buy all this stuff..
    VN1 Auto V6
    Dec 2004
    Thanks for the offer Haydz mate, but it looks like it MAY have sorted itself out.. it may have been the ecu reset? I left the efi fuse out over night just to see if that woudl fix it..
    It fixed the rev issue but not th estarting which is worrying me.. i really do think its an ignition problem now.
    Lucky with these cars its just a case of changing:
    Plugs
    Leads
    Coils
    DFI
    and your ignition system is sorted :P
  1. Cant rev past 3500
    By FullySik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2008, 07:22 AM
  2. Plz help 4th gear auto wont work
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 01:29 PM
  3. auto wont go higher than second gear
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 11:16 AM
  4. VR V6 auto wont go past 2nd gear
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 12:01 AM
  5. VH 253 auto wont change out of 1st gear
    By jimmyd17 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2005, 09:33 PM
