Results 1 to 18 of 18
Thread: Engine Symbol
    Nov 2003
    Hi there Vn drivers and Admirers,
    I have a VN 89 V6 Commodore.
    I have a funny problem with it that Holden themselves couldn't find. At the end they told me to replace the ECU which I did but the fault is still there.
    Anyway the problem is that when I am driving the car (mainly it happens on hot or humid days) the engine symbol comes on the dash.
    I know that you can count the value of it, but the symbol comes on for 20sec consistantly then goes off for around 10mins then sometimes it comes back on again for around another 20sec.
    How anyone else had a problem like that before? If so please help !!!
    Thanks
    Regards,
    arty
    Nov 2003
    I only got engine symbols when I rebult my motor and used the stock chip. I knew I was going to get running rich all the time. I know the only time my light came on was to inform I was running rich, or running lean.
    I cant think of the wires in the plug you short out. If you read through the list somehwere here on this site, it tells you how to diagnose what the engine lights mean. It wont flash at you the codes your wanting when driving in everday conditions, you have to insert a wire between 2 terminals in the ADL something or other plug, then turn yuo igntition to on thats when it starts flashing the whats wrong code.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    hey sport, i had a very very similar problem with the vn, have a look at your exhaust manifiold, check the o2 sensor, if it's got a intermitent fault, it will come on, and go off, and come on, and go off, nothign major, mine was a crack/split in the webing, they are cheap to replace, how ever, holden dont have exhaust manifolds anymore, had to get it from the wrecker's, all is fine now, no more problem with the lboody thing, for some reason, it didnt show up as a fault code on the ecu.
    i am the god of britany spears womanizer on just dance on the wii
    Nov 2003
    QUOTE (Garth @ Jan 20 2004, 06:19 PM) hey sport, i had a very very similar problem with the vn, have a look at your exhaust manifiold, check the o2 sensor, if it's got a intermitent fault, it will come on, and go off, and come on, and go off, nothign major, mine was a crack/split in the webing, they are cheap to replace, how ever, holden dont have exhaust manifolds anymore, had to get it from the wrecker's, all is fine now, no more problem with the lboody thing, for some reason, it didnt show up as a fault code on the ecu.
    Hi there,
    Thanks for that Garth, I'll check that out and I'll keep you guys posted.
    Regards.
    Arty
    Grantis1976 Guest
    If your engine light is coming on, dont ignore it. Its there for a reason, to let u know of a little prob. before it becomes a BIG problem!
    Good Luck !!!
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    I agree with Grant, it aint there for the hell of it.
    Selling FG G6E Turbo and buying a N/A Supra
    Nov 2003
    Nov 2003
    Hi All,
    I notice you say to check the o2 sensor. Is that the oxygen sensor by any chance.
    If not where is the o2 sensor because I have been in my trusty Gregory manual and I can't seem to find it.
    Regards,
    Arty
    Garth's Avatar
    not telling
    Oct 2002
    o2 sensor is on the exhaust manifold, stand on the passanger side of engine bay, and look at the exhaust maifold, you will see it goes down to the flange, just above the flange is the exhaust manifold, but check to see if you have any problems with the manifold it's self, look for cracks, split's stuff like that,
    go to the commodore specs and info section on this site, you will see there what you need to do so you can get a fault code reading out of the ecu. i would be doing that first. all the codes are their also.
    follow the directions for exctracting codes down to the tea, if you dont, you can kiss the ecu goodbye
    cheers
    garth
    Nov 2003
    QUOTE (Garth @ Feb 9 2004, 04:10 PM) o2 sensor is on the exhaust manifold, stand on the passanger side of engine bay, and look at the exhaust maifold, you will see it goes down to the flange, just above the flange is the exhaust manifold, but check to see if you have any problems with the manifold it's self, look for cracks, split's stuff like that,
    cheers
    garth
    Hi Garth,
    Thanks for your help.
    Regards,
    Arty
    Jul 2006
    gday i got a fault with my vp commodore engine light flashes and motor goes to cut out replaced the crank angle sensor coil pack have found no loose wires can some one help thanks stump
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    VS S1 Statesman V6
    Dec 2006
    hey guys, I use to have a VR Calais that used to have that exact same problem. I know that the engine light is there for a reason but I did just leave it, turned out to be the o2 sensor whch it also known as the oxygen sensor. Anyway I did just leave it and the problem ended up out lasting the transmition and gearbox itself so no real biggy
    VP Commodore
    Jan 2005
    Having trouble with my VP cutting out, checked the codes, fan comes on but then keeps cutting in and out. when the fan is working code 12 appears however the fan is intermittent for a reason does anyone know why? Engine light remains on
  15. #15
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Is it cutting in and out when the car is hot, or does it cut in and out at all times, including when the car is NOT up to temperature.
    What we need to find out, is if the fan cuts in randomly when it's not supposed to, or if it's turning on when it's meant to, but then cutting out occasionally. If you catch my drift.
    I would suggest either faulty:
    1) wiring
    2) relay
    3) fuse
    4) fan motor
    5) coolant temp sensor
    6) signal from ecu
    The 1972 HQ Kingswood
  16. #16
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Ziggie View Post
    Crank sensor, I bet it's been pretty hot in Adelaide the last couple of days
  17. #17
    VP Commodore
    Jan 2005
    Thanks guys
    i think i found the problem, gave the ecu a whack when the motor was carrying on like an unregistered dog and bingo it started running properly again. took the ECU apart, cleaned up the terminals and chip, hit it with CRC and so far so good.
    Ziggie
    Drive for show, putt for dough
  18. #18
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I don't think the OP is coming back :P
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. defacing the allmighty holden symbol
    By The Darkness in forum General
    Last Post: 13-01-2007, 03:49 PM
  3. air bag symbol
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2006, 06:01 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Sv Symbol
    By meh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2004, 03:32 PM
