Results 1 to 10 of 10
Thread: Rough as guts!
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    Unhappy Rough as guts!
    Hey guys,
    Well here is the scenario. Car wasnt starting and stalling awhile back and began running rough suddenly. Leads, IAC valve, spark plugs have all been checked, double checked and changed but the VN is still running incredibly rough. Also checked kickdown cable and its fine. When I changed the leads over, that seemed to have made it better (not stalling anymore), but still sounds like it missing on a cylinder or something. Took for a test drive and it has absolutely no power when you floor it either. If anyone got any ideas, I really need your help. I'll try give you as much helpful information as I can.
    Well firstly the fuel pump had been whining quite abit before all this happened. I know the pumps normally buzz away but mine was whining really loud! The pump was replaced when I bought the car and it was running on very low fuel supply. Could this possibly be the problem??? Will check the fuel system pressure but just wanting some prior knowledge so I can source out whats wrong. It doesnt stall at the moment but it idles real bad like it has a hot cam if that makes sense to someone. Im thinking that it may be a fuel issue. Checked injectors resistance as well and it was all good. Its when you accelerate it seems to be really rough. Lack of fuel pressure maybe?
    Any help would really be appreciated.
    Cheers, Rhyan
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Maybe worth checking the coils with some know good ones.
    Are you getting good spark - like if you hold the lead just away from the plug - do you get a nice strong blue spark jumping across to the plug.
    Use well insulated pliers.
    and 3 Dangerous non ABS VN's
    1989 VN Berlina
    Jul 2008
    Quote Originally Posted by 88GreenVN View Post
    Yes spark is pefect. Took all the plugs out and cranked the motor and got a nice blue spark. All plugs are burning really well and tested the coil pack and its perfect. Lost for ideas...
    88GreenVN's Avatar
    Jun 2006
    You do have the leds in the correct firing order yes - can make them run like a bag of pooh if they are mixed up.
    1989 VN Berlina
    Jul 2008
    Yeah, ignition side of things is all good - trust me. Double checked, tripled checked and so on. Its definitely sparking and leads are in order
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If your confident of all that then check the fuel pressure and go from there. How many k's on it. Not a compression issue.
    Reaper
    1989 VN Berlina
    Jul 2008
    Quote Originally Posted by VrWagz1 View Post
    It has around 250,000 on the odometer. All plugs however are burning a nice tan colour, which seems a good indication of good compression. Also checked the cylinders when changing the main bearings and conrod bearings for compression and there fine.
    88GreenVN's Avatar
    Jun 2006
    Have you run injector cleaner through it at some time? Possibly fuel related.
    1989 VN Berlina
    Jul 2008
    Exclamation Fuel crisis lol
    Yeah its fuel related... well sorry "it was" fuel related. Itsall good now And I mean its running beautifully! Removed the fuel tank and was horrifed to find fuel that looked the colour of coffee. Flushed the tank out a few times with 20 litres of thinners and replaced the fuel filter which was pretty much brand new but clogged with rust and sludge.
    Then ran down to the servo and got myself some premium unleaded and filled the tank with 15 litres. After I got it started I was disappointed at the time because it still ran rough. I then drove down to the servo and added injector cleaner and filled the tank full with premium. Took it for some good 100 kilometre runs and all of a sudden I have 6 cylinders again!!!
    88GreenVN's Avatar
    Jun 2006
    Now that a horrible thing to find coffee coloured fuel. Bet that was a suprise to you
    Car is probably so thankful for you taking the tank out to have a look inside.
    Good job
  1. Guts vs. Balls
    By BlackVXGTS in forum Jokes/Humour
    Last Post: 07-08-2008, 03:41 PM
  2. Replies: 0
    Last Post: 09-12-2006, 06:34 PM
  3. Show us your guts!
    By SIXAPPEAL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2006, 08:47 AM
  4. My VL running as rough as guts (wont idle well)
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-08-2005, 09:08 PM
  5. vl rough as guts
    By muffman001 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2005, 01:46 PM
