Results 1 to 7 of 7
Thread: back seat removal
    vn executive
    Nov 2008
    Default back seat removal
    can any one tell me how to take out top and bottom rear seats so i can fit car seat covers?
    i also have a problem with windscreen washer switch refusing to work, has been replaced twice
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    im sure there is a thread somewhere
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    vnss
    Jan 2005
    s.e melb
    stick your hands between the top and bottom section of the seats and lift the back of the bottom seat and sort of slide the front towards the back of the car (god i hope that made sense).
    there will be 2 10mm self tappers holding the top section on, ramove them and lift the top up releasing it from the hooks.
    not sure about the washer switch
    89 VN 5lt
    Mar 2005
    Busselton W/A
    might not be ur switch could be the the pump on the washer bottle , might be stuffed
    VN S
    Oct 2006
    hmmm, to kind of expand on what wildss said this is what i do.
    Get in the back of the car facing the back. stick ya hands in the gap and pull the back of the bottom part of the seat out. There's a wire part of the frame of the bottom seat that hooks into two hooks about a third in on each side, so then kinda put a lot of force with one knee onto the seat pushing it towards the back of the car. It'll spring up and you'll know when it's out, then do the other side.
    You might be able to put your covers on the back bit witout taking it out completely, I didn't take mine out to get my covers on
    Edit: yea, pull the plug off the pump that's clipped into the reservoir and stick a multimeter in it on volts. See if you get 12V there or not, that's prolly the best first step
    VP Wagon
    Oct 2008
    I had a similar problem with my windscreen washer switch, where despite changing the switchblock with another it refused to work. It eventually turned out that the metal strip on the back of the washer switch was not touching (this was the case for both of my switchblocks, lol), if u dont know what im talking about, take out your switchblock and look at the back of the washer switch, when you press the washer button in, a metal strip is touched. Make sure it doesnt have any muck on it, and bend it back until it is properly touching the washer button when it is depressed. It should work then.
    If thats not the problem, with the wipers still working when you press the button and the pump is working (if you hear a buzzing noise its working), then its time for a clean of the hoses and nozzles. Take the black rubber hoses off the bonnet nozzles, and see if they flow water. If not (unlikely), clean them out using some flexible rod of some kind. If they do flow water, then its the nozzles that are the culprit - Take them off and blow through them, if no air is going through then its blocked hard. Use a needle and push them through the little nozzle holes, until you can do the aforementioned air test successfully.
    Hope this helps
    vn executive
    Nov 2008
    thanks guys for the advice, i'll look into it
  1. Back Seat Button... Removal?
    By zerocool27 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2010, 04:29 PM
  2. back seat removal
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 09:22 PM
  3. back seat removal
    By sarj in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-08-2006, 03:16 PM
  4. Seat removal help
    By crazyspoon05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 01:24 PM
  5. Back Seat Removal
    By ducatis in forum Car Audio
    Last Post: 29-07-2005, 04:42 PM
