Results 1 to 3 of 3
Thread: VP coolant question
    VP Berlina
    Sep 2008
    Default VP coolant question
    Hi there,
    When I service the car, Everytime I drain the coolant I only get about 5 litres out. The service manual says the cooling system is approx 10 litres so I expect to get at least 9-10 litres of old coolant drained out right! I remove the drain plugs under each of the headers, undo the cap and remove both hoses from the radiator. One thing I noticed is that no coolant actually comes out of the drain holes where I have removed the drain plugs.
    The only way I am sure I have drained all the old coolant out is to connect everything backup and fill with water then run the engine for a bit then remove the hoses and drain. I repeat this process about 4 times till the only thing that comes out is just water. Then I do it another 2 times with distilled water and then finally fill the system up with coolant. I assume there is liquid trapped somewhere? when I fill it up I only get 5 litres of coolant in before it fills up.
    Any suggestions
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by spoonfork View Post
    Hi there,
    Any suggestions
    Blocked drain plugs? perhaps undo the drain plugs while the system is hot and under pressure and see what happens.....but wear some rubber gloves and protective gear to protect yourself from the obvious.
    Possibly the heater core is worth 1-2 litres, but dont know about the other missing litres. Theres really no way of emptying the core unless you syphon it out, or you can try blowing compressed air through them. Best just to disconnect a heater hose and run the garden hose through the core until it runs clean.
    VP Berlina
    Sep 2008
    Yes everytime I've filled and drained the system with water, the plugs have been left off. Yes I've run the car without the plugs and still the same nothing coming out of those drain holes.
  1. vn series one coolant question
    By taskmaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2008, 11:18 AM
  2. COOLANT FLUSHING Question...
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2008, 04:34 PM
  3. Question re bypass coolant hose on VP Commodore
    By Frogman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2008, 01:33 AM
  4. coolant question
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 11:56 AM
  5. coolant question...
    By Lish in forum General
    Last Post: 04-01-2006, 11:22 AM
