I want to know how to change the drive belt tensioner(if you can remove the nut holding the wheel that the fan belt is tensioned with) if one can ?
yeh u can remove the nut its a reverse thread though - good luck its onthere tight as... take the belt off first
thanks ,but what do you mean when you mentioned its a reverse thread? to undo the nut do I go anti clock or clock wise ?
yeh same as a gas bottle thread - what u would normally tighten is actually loosening ............... turn right to loosen left to tighten.
think by memory u put a spanner on and pulll it left to release tension to get belt off - once done use same spanner and turn right to loosen nut
thank you for your help Vt-Brrlina
Body by Holden, Soul by Brock
the Legend will live forever
