Results 1 to 14 of 14
Thread: VP Hard Shifting/Kick
    Hardstylin is offline Banned
    VP Calais
    Aug 2008
    Melbourne, Victoria
    Default VP Hard Shifting/Kick
    Hello,
    My VP Calais is in the process of being roadworthy, so I'm slowly troubleshooting all the problems/potential problems.
    I'm unsure if it is just my transmission/shift kit, although my VP kicks hard when it shifts, the higher the revs, the harder it kicks.
    I have a 700 Turbo Transmission and a Stage 2 shift kit, is this something I should be worried about/have checked out? Or is this just the way it is?
    You really have to be in the car when it shifts to know what it is, although I'm sure some of you have had similar experiences.
    Cheers,
    Chris
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by Hardstylin View Post
    Hello,
    Cheers,
    Chris
    My V8 VP Calais is the same especially from 1st-2nd, in the wet crazy to control gotta take it real slow, it'll kick out hard. Changes slightly when in the non-overdrive D, bit better to drive (but miss overdrive).
    1993 Series II VP Calais
    Sep 2006
    lololololol
    1) of course it'll change hard with a stage 2 shift kit, that's the idea
    2) the non-overdrive D means the car doesn't use 4th gear...that is all...doesn't affect the way any of the other gears change
    cogez
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Cogez View Post
    lololololol
    cogez
    When I drive in Drive it changes gears harder, but in Overdrive its smoother and chages earlier. So your 2nd statement isnt always true, this is only with a stage 1 shift kit also.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    as long as it doesn't jerk on the down shift when slowing down like mine does lol seems stuffed , mines got corvette servo or whatever so i was told, yer scary in the wet with 1st to 2nd in the wagon lol
    ========My Statesman 20's Mafless and 3.9's========
    NO CAR ATM.. -.-
    Jul 2006
    agree'd with mack! its strange but true.. unless the kick down cable is tangled :P
    Vp series 2
    Jun 2008
    adjust thekickdown cable and take it for a drive and plant it to check the changes then same but light on the foot.
    Been driving a stage one with corvette se4rvo recently and it kicks something feirce on the way to 2nd then smooths out a bit. the changes are a little better with the foot down. have notice that if you plant it then lift a little the thing kicks up a gear and throws you around a bit.
  8. Default
    have a go adjusting the kickdown cable. mine was so tight that the throttle body didn't open 100%... but i liked it holding gears for that long. i adjusted it now so the kickdown is as tight as possible at wot. i think that's where it's meant to be now.
    but yeah it's normal: YouTube - VP Drive By
    Quote Originally Posted by zai View Post
    I am not sutpid
    VP Calais
    Aug 2008
    Melbourne, Victoria
  10. Default
    what do you think happens when you hear the wheels chirping
    if that was in the wet i would have been inside a house.
    it's just a hard shift. you'll also get used to it. i found it very weird and i hated it at first. a couple of weeks later, it felt weird to drive a car without it. just be very careful in the wet.
    I am not sutpid
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    That's what shift kits / corvette servo's do. They make the shifts alot harder and more aggressive. Have it taken out if you don't like it......
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I'm gunna hijack this a bit here, but is there an easy way to tell if a previous owner has installed a shift kit? My VS changes heaps harder and faster than my old one did
    VP Calais
    Aug 2008
    Melbourne, Victoria
    vp 5L
    Jul 2008
    goldcoast
    i would just like to clear something up , with these shift kits , for those that have had them intalled buy just pulling the valve body out , this is only a stage 1 kit even though u have brought a stage 2 and 3 kit ,you have only installed half the kit , this will firm up your shift from 1st to 2nd ,and u can even chose how hard u want it to shift , to install the rest of the shift kit your box needs to come out and pulled appart for the rest of it to be install once this is dun this will firm up the rest of the gears abit and stop the common problem that the t700's have witch is 3rd gear clutch plates buring out
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. Clunk when shifting 2-3
    By omar302 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-10-2010, 01:15 PM
  3. auto shifting
    By shumway in forum V6 Development And Modification
    Last Post: 31-01-2007, 06:05 PM
  4. auto shifting
    By bigbos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 07:59 PM
  5. Down shifting probs
    By calaisalltheway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 08:57 PM
