just wanted to know the best gap atm iv sot it set at 1.3 mm is that right?
what do you have yours set at?
should be about 1mm
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
what electrical system components are you running?? if you have it beefed up you can run a wider gap, also did you use just use some pliers to adjust the gap? sometimes you cant get it dead on without the proper adjustment tool.
I run 1.1mm gapping.
havent heard from you in a while whats been the go?
i read somwhere that vn/p run 1.1mm and the vr runs .8-.9mm(i think, could be .9-1mm too). I dont know why that is, they are the same motor. But my vr definatly runs alot smoother especially at idle @ .85 compared to 1-1.1mm. I'd be inclined to try both and see which runs best for you.
I'm running platinum plugs though, not just standard ngk's
