Results 1 to 6 of 6
Thread: VP Lexcen Light Problems
    VT Calais 3.8
    Nov 2008
    Default VP Lexcen Light Problems
    Hi Guys,
    Newbie here, i friend just gave me a car for free and it's a VP Lexcen as far as i can tell, the problem is it is a bit of a bomb. I'm on top of most of the work it needs but i has a wierd problem with the headlights and tail lights/brake lights coming on whenever the brake is pressed.
    This happens at all times, even when the car is off and the key is not in the ignition.
    Does anyone have any ideas of what the issue may be?
    I've checked the fuses and they're all fine.
    Cheers,
    Voney
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Youve got power crossed with the brakes and headlights. When the brakes switch is activated - foot on brakes the power should only go to the tail lights. Your brake lights are live all the time in so far as car ignition on or off.
    You will need to get a wiring diagram and follow the wires as best as you can - look for a place where the loom may have been hacked at. Most probably under the dash cluster/fuse block.
    and 3 Dangerous non ABS VN's
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    check your bulbs.... they have a habit of doing this when the wrong bulbs are put in the tail lights... seen it 1000 times lol
    SIR LS1
    the two ton go kart
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    i have also had a similar problem on another vp of brake lights randomly being on... the brake light switch wasnt ajusted properly
    SIR LS1
    the two ton go kart
    VT Calais 3.8
    Nov 2008
    Quote Originally Posted by davecunno View Post
    What bulbs should be in there? Currently it has those dual filament style ones for basically all the lights back there (i had to replace a few but the same style were already in there...)
    Yeah i did have a problem with the brake light switch originally but it works fine now, it had fallen out and i didn't have brake lights at all....
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    check the workshop manual or a narva automotive guide.. id say thats ya problem
    SIR LS1
    the two ton go kart
  1. VP Interior Light & Alarm Problems
    By cobra11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2008, 08:54 AM
  2. Warning light and brake problems
    By bazzii1388 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2008, 12:26 AM
  3. Vp problem HELP !!!!!interior light problems
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2006, 01:59 PM
  4. WTB******LEXCEN tail lights, vp style lexcen only please
    By UNEQVN in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 03:00 PM
  5. VT Tail Light Problems
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2005, 10:51 PM
