Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: VP 304 slug
    VP Executive 5ltr
    Oct 2008
    campbelltown
    Default VP 304 slug
    hi guys i have a VP 304 not the original motor was a V6 any way i dont know if it is a slug or if that is just how it is but thinking back to my old VK 308 i think it went harder.....when you take off for the first 10sec it gose good then feels like the power drops out a bit...i know this is not much to go on but i have only driven the car 2 times...but would still like some in put to what is causing it to have a power drop if it is having a power drop
    Nat
    calaiscruzer's Avatar
    calaiscruzer is offline I drink beer, and I vote!
    Atlas Grey VN SS
    Sep 2007
    VIC
    could be the fuel pump or dirty fuel filter so is leans out when floored? vk's are a bit lighter but not as much power so dunno about that.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Do the normal thngs like plugs and leads - maybe a rotor button & dizzy cap & fuel filter.
    Then get a tuned memcal.
    and 3 Dangerous non ABS VN's
    VP Executive R-spec
    Jan 2005
    Chances are there's somethng wrong with it, a standard VP 304 is infinatly faster than a VK with a 308
    VP Executive 5ltr
    Oct 2008
    campbelltown
    hmmm if you floor it are they weant to spin??? mine when you floor if you get little churpies but has a LSD i would think if it did not have a LSD it would spin
    Morton's Avatar
    Fairstar the Funship
    May 2006
    What sort of tyres have you got on the back? My bog stock V8 Auto Statesman would light up the rears with LSD and IRS.
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    howepower's Avatar
    howepower is offline Donating Member
    vc commodore sl
    Nov 2008
    KIELOR DOWNS
    VP Executive R-spec
    Jan 2005
    PS after 10 seconds in a stock 304 you would be doing anywhere between 120 and 130km/h
    VP Executive 5ltr
    Oct 2008
    campbelltown
    Quote Originally Posted by Morton View Post
    i have LSD IRS and the tyres are 235/40 or 45/ 18
    don't know the brand of tyres
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    First thing to do is check the fuel system. Make sure it is running the correct pressure (I think mine sits at around 40lbs) in the fuel rail. Next make sure your ignition system is up to spec. New dizzy cap, rotor button, leads, plugs and coil if they look like they haven't been changed in a while. Check your timing is set correctly (10 deg with the computer set in diagnostic mode).
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VP Executive 5ltr
    Oct 2008
    campbelltown
    Reaper
    ok i will do the timing today but can some one put up a pic of where 10 deg sould sit and where is the plug so i can put the computer in diagnostic mode
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    EDIT double post dont know how that happened
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Run enigine to normal operating temp.
    Connect timing light to no.1 spark plug lead.
    With engine idling copnnect a paper clip or thin wire across A and B in diagram i posted (black and White wires). The diagnostic connector is located in pasenger footwell next to kick panel and underneath glovebox will look like the picture i posted.
    Use the timing light to check timing against the mark on the crankshaft pulley against the timing marks on the timing cover.
    Timing is 10 degrees BTDC (Before Top Dead Center) or also Advance side of TDC mark. Each mark is 2 degrees therefore you should be 5 marks before the TDC on the advance side.
    If your timing is out you'll need to loosen your distributer clamp and adjust dissy till it is correct. Retighten clamp and check timing again to make sure it hasnt moved.
    If all is good remove diag connector bridge wire and away you go
    EDIT Picture can be found in this link as i cant upload same picture twice
    help!!! ecu problems
  15. #15
    VP Executive 5ltr
    Oct 2008
    campbelltown
  16. #16
    VP Executive 5ltr
    Oct 2008
    campbelltown
    ok went to do the timing today and hmm well when you briege A and B are the rev's ment to go up or down???? mine stayed the same was also holdeing the RPM's at 1800 and briege them and still nothing the revs just dont move
    and just to make sure this is the plug i was brieging the 2 end ones on the right
  17. #17
    VP Executive 5ltr
    Oct 2008
    campbelltown
  18. #18
    Vp series 2
    Jun 2008
    umm read the posts mate.
    These guys have taken the time to answer your very vague question the least you could do is read them.
    Basic tune up like you do when you buy a car.
    filters oil plugs leads dizzy cap and rotor button.
    also check for error codes and check timing.
    VP'S will tell you what is wrong most of the time.
  19. #19
    VP Executive R-spec
    Jan 2005
  20. #20
    Jun 2005
    haha yeah was about to say that foam. plug should be 2 rows, 4 pins long, with two pins missing on the bottom row if i remember. its hiding above your ecu on the passenger side
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  21. #21
    VP Executive 5ltr
    Oct 2008
    campbelltown
  22. #22
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    Theres no way in hell your going to spin 2 x 235 tyres with irs on a stock 5 litre -EDIT without doing a linelocker EDIT-. What i used to do in the statesman is rev up to around 2500 rpm with the foot on the brake and mash the accelerator, i used to only chirp the wheel in the dry and that was with a single pegger : p put some 205's on it and youll have no trouble.
  23. #23
    VP Executive 5ltr
    Oct 2008
    campbelltown
    Quote Originally Posted by vnv8driver View Post
    Theres no way in hell your going to spin 2 x 235 tyres with irs on a stock 5 litre. What i used to do in the statesman is rev up to around 2500 rpm with the foot on the brake and mash the accelerator, i used to only chirp the wheel in the dry and that was with a single pegger : p put some 205's on it and youll have no trouble.
    it willl spin just wont light them up like foot to the floor in 1st (auto) and it like it just sits on 3000 and wont rev up any more....my mate has a VP 304 and it will light them up but i think he is running 15 or 16
  24. #24
    304 Calais
    Aug 2007
    Up your mum
    thats what i meant sorry, you do mean doing a line locker? i meant just flat chat from the lights without stalling it up it wont spin, whats your mate running? theres alot of factors such as tyre brand and rim size,as well as modifications. Even with a full set of bolt ons it gives the 5 litre a kick in the bum.
    Look at getting a new tune, exhaust, cai and shift kit for flatout performance.
  25. #25
    304 Calais
    Aug 2007
    Up your mum
    and you might see it as being a downgrade, but it actually makes you faster overall off the mark with the wide wheels and irs.
    Did you put the LSD in yourself? if its standard you will find it will be a single pegger.
  1. WH Statesman with 5.7l is a slug
    By jdonly1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2008, 10:44 PM
  2. vt 5l slug
    By Burnout_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2007, 05:47 PM
  3. goes like a slug vt series 2
    By megaman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2005, 06:22 PM
