Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 139
Thread: Converting VN to Climate Control
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Converting VN to Climate Control
    I'm going to see if I can put a Climate Control setup into the 88 Wagon without swopping the heater box. (Edit - cant do this)
    I've purchased all the bits that is needed as far as I know - plus also the proper CC heater box too just in case I fail.
    I've got 1991_Vn2nV's wiring instructions and plan to take some photos and draw up some plans of the plugs and colours diagrams - along the lines of the L3 dash upgrades. Thosse diagrams make is so much easier to make the upgrade and use them all the time. (added 3 items to the notes to do a complete install)
    The reason for this is I have all the CC bits and the A/C is already very cold in the wagon. If I dont have to take it out I wont.
    I dont know about anyone else - but I love the climate control in the V8 and think it will sit well in the 88 Wagon.
    Last edited by 88GreenVN; 11-01-2009 at 09:21 AM. Reason: Must chage the heater box
    and 3 Dangerous non ABS VN's
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    If not doing the heater core swap I really reccomend swapping looms man. Its so easy, just plug and play once you're done.
    As far as I know you should just be able to swap the resistor in the top of the heater core and the bottom little box thing plus the actual plug and wiring for the heater core and it should work (the standard heater core to CC heater core).
    88GreenVN's Avatar
    Jun 2006
    The wagon as a Calais loom in it already. I have the wires from a cliamte control. So here goes.....
    Photos later today of all the bits.
    88GreenVN's Avatar
    Jun 2006
    OK here is 3 photos of some of the bits needed.
    I'll get photos of the other bits tonight and put lables on them
    VN Sedan
    Jan 2007
    Latrobe Valley
    cool...I'll watch this very keenly....might save me some money on regassing.
    88GreenVN's Avatar
    Jun 2006
    Biggest issue I can see at this point (re taking heater box out) is getting one of the sensors into the heater box - goes inbetween the fan and the main box.
    Edit - looks like the heater box must come out to get the sensor in.
    88GreenVN's Avatar
    Jun 2006
    When replacing a dead blower fan in the VN - Do you have to take the whole heater box out?
    88GreenVN's Avatar
    Jun 2006
    OK looking through the VQ book last night and it looks as if you can change the intake sensor without removing the heater box. (Wrong)
    So I'm working through the wire diagrams and now just need to pull the wagon a/c switches out to see what colour wires it has. The Blue A/C plug I have dosn't have the same wires as 1991_Vn2nV has a brown instead of a green black.
    Very close to a goer now - have all the parts and ready for the xmas time swap.
    88GreenVN's Avatar
    Jun 2006
    Here is the tricky bit. I pulled a heater box apart on the bench to see how I could put the sensor inside the core. Comes apart easy enough - but getting the sensor plugged into the correct position will require a special tool to be made.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Zuicider View Post
    was easy pulling apart but **** putting it back in
    Yep - but the special tool making is all part of the challange. If I can get this part done the climate may just go into the car without replacing the heater box and require a A/C re-gas.
    1991_Vn2nV's Avatar
    Mar 2006
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    I don't think i've heard of someone doing it this way before. Could be a first?
    I've not found anyone who has done it this way either.... But cant see why not - except for the sensor into the middle of the box. I'll bend up a screw driver and weld a pike thingo on it.
    I have 2 climate control heater boxes so if it all goes horribly wrong I can chuck a complete box in.
    But if I can do it without disconnecting the A/C I can save $150 on a re-gas and new seals.
    VN Sedan
    Jan 2007
    Latrobe Valley
    is it easy enough to get the core out off the heater box without taking it out of the car?....I haven't had to change a heater core yet.
  15. #15
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    im going to all holden spares tomo to pick up a Vs stato dash, loom and full climate control setup for my ute, already have the level 3 dash ... should be verryyyy niiice
    love what ya doing with your car man.. good to see someone who thinks like me
    SIR LS1
    the two ton go kart
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by davecunno View Post
    Yep great upgrade to do.
    With no footy on now what else is there to do but to play with the cars.....
    And now that the wagon is a "Stealthy Calais International" it needs climate control and a V8.
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Nevyn View Post
    Without dropping the coolant no. - But that maybe the solution. I'll play with the screw driver process more tonight after work.
    One thing I just thought of is where the probe goes into the box it has 2 screws to secure it - dont know if the standard box has the holes. Bugga - just got to work and now I'll have to wait until I get home to have a look at the standard heater box........
  18. #18
    88GreenVN's Avatar
    Jun 2006
    Looks like what the probe is secured into the climate heater box is pop riveted to the box. So this could be bit of a pain. The climate box I have as a "mule" can give me the thing to incert into the original heater box. The shaft looks the same - just press the cog onto it for the control motor. So its drill the 2 pop rivits out and see what goes. (the climate box is broken and not servicable so I have no problem hacking into it.
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Pick up a standard heater box on friday to experiment with - cut holes in for the sensor to go in. Friday could be a fun day
  20. #20
    VN Sedan
    Jan 2007
    Latrobe Valley
    the CC box I picked up for the blue VN got broken, so looks like I'll have to do the same as u now 88 whether I want to or not......and as for loosing coolant, thats no deal, I'm using the cheap kmart stuff at the moment till I work out where its leaking from.
  21. #21
    88GreenVN's Avatar
    Jun 2006
    I have 2 set of CC bits ready to go. So Fridays test is looking to be a good fun day. Getting the bit out of the CC heater box and into the standard box is the challenge.
  22. #22
    VN Sedan
    Jan 2007
    Latrobe Valley
    I though that would be the easy part (getting the bits out) cos u can rip the box apart....putting them into the box still in the car is what I see been the hard part.
  23. #23
    88GreenVN's Avatar
    Jun 2006
    I just want to get the bit that's pop rivetted into the bottom of the heater box without killing it. Them mount it into a standard box. Looks to be the biggest task to get around.
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Only got 5 mins on this Friday - I found the bottom of the old heater box from the 91 sedan behind the shed. It looks like all I have to do is cut 2 holes in it and drill 3 holes - It's maked on the plastic.
  25. #25
    88GreenVN's Avatar
    Jun 2006
    Here is the biggest challenge to date. Cuting these holes out is easy - but behind the cut outs on a climate control heater box is a metal plate.
    I'm going to try use a sealer glue to holde the sensor in place and the air tube. If that bit works - good to go I think.
  1. Climate Control
    By E_ri_k in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 10:58 PM
  2. Climate Control
    By VSBerlina95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2006, 10:09 PM
  3. converting to climate control vu/VX can it ?
    By OMR001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2006, 09:11 AM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. What exactly is climate control?
    By DavidPartay in forum The Pub
    Last Post: 01-02-2005, 05:58 PM
