Results 1 to 5 of 5
Thread: BCM in VP??
    VNCPTR is offline Banned
    90 S2 Atlas Grey VN SS Manual
    Dec 2007
    Default BCM in VP??
    hey all,
    Im just wondering where abouts the BCM is in the VP, as i need to change one so i can pick up a car, (The guy has miss placed the remote for the immobiliser)
    Is there a way to by-pass them, could i just un-plage it and turn the key and it will start or dose it need the bcm pluged in?
    it is a VP Calais S1.
    Cheers VNCPTR
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Should be under the steering column pretty close to right hand side air duct. Not sure about the other q's, sorry.
    Vp series 2
    Jun 2008
    i thought the vp bcm was under the glove box?
    does he have the other small key to shut off the uimmobiliser system.
    it goes in the key in the front passenger door pillar, if he has the one to turn it off then it turns off the immobiliser so you can start it.
    if you can work out which wires to join from the lock then you can turn it off or get the key number and get one cut.
    Dan355's Avatar
    May 2006
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by centy View Post
    Thats the ECU, the BCM is under the the steering colume as dan said i think all ya gotta do is take off the air duct 2 gain access 2 it.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
