Results 1 to 3 of 3
Thread: vp wheel spec
    VP Executive
    Apr 2005
    Default vp wheel spec
    hi i've got vp and i want to change the wheels buying from oversea. does anyone know the wheel spec? i don't really understand as well but the guy asks me about the holes and p.c.d.? pls help.
    thanks
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    Apr 2005
    Quote Originally Posted by SlowVac
    The offset I think are 5x120
    Thats the PCD(sorry 2 correct u Slow Vac)- pitch circle diameter, just means amount of studs required and the diameter that they're situated. If u measure the distance from the centre of the hub 2 the centre of a wheel stud, u'll find a measurement of 60mm, which is the radius measurement. Double that = diameter- easy as that! Offset is how much the rim sticks in/out in relation to the centreline of the rim. A negative offset means the rims stick in the guards more(narrower track width), whereas a positive offset means ure wheels are closer 2 the guard lip(larger track width)Excessive trak width either way causes undue loading on the wheel bearings causing premature failure, thats why u wanna make sure this is within the limit 2 avoid the ecilops giving u a defect!Hope this helps
  1. L67 Spec ???
    By sixshooter in forum V6 Development And Modification
    Last Post: 19-11-2011, 10:21 AM
  2. VN Vacationer spec
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2009, 11:58 AM
  3. any 1 have a spec sheet for a cam
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 12:05 PM
  4. CAS bearing spec
    By vlrad in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-08-2005, 01:49 AM
  5. VN-VP Engine Spec
    By Triggb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2005, 08:58 PM
