Results 1 to 25 of 25
Thread: Can I use an Ecotec coil pack in my VN s1?
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question Can I use an Ecotec coil pack in my VN s1?
    Looking for a nice cheap s2 onwards coil pack for the VN as I'm currently running on Paul's (Zuicider) spare one..
    I've been hunting on ebay to no avail... til Paul found an Ecotec one nice and cheap. Are they a direct swap?
    Sam
    WTB: mulberry VN interior parts
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I dont think you can.
    VN-VP coil packs are squarer than the VS-VT ect...
    I read somewhere that they wern't interchangable because of the ecu program they ran on.
    But I could be wrong as i never tried it when i had the VN
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Coil pack's should be the same vn s2 - vy as far as im aware, just the DFI module im not sure about.
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    you CAN use an ecotec coil packs..u need to use the dfi module from the same motor also..
    i have done this to my vn, and it mader a difference to the runnin effects...much better spark..
    if u use the ecotec coils and dfi, use the injectors also. runs heaps better..
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Won't be changing injectors.. not without a chat with my tuner anyway..
    So you need the DFI module as well.. never done one of those, which part is it?? (Don't even know what it is haha)
    Sam
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    dfi module is the flat metalplate the coilpacks sit on - should have a long wiring harness going into one end of it
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yep ecotec coils packs and dfi will work fine just remember when you go to take the wiring plug off the dfi that there isd a bolt that holds it in
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    haha yea I know, came across that changing my first one out on the side of the road haha
    Is the plug the same for the Ecotec ones? Direct swap??
    Sam
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeap should be
    vt 2000mdl exec vl berlina
    Apr 2008
    hey guys sorry for the bumo but need help asap i have s1 vn and am trying to put the vt coil pack and dfi on but how do i do it as the frame holder on the vn doesnt allow the vt one to be staight swapped over
    VN Exec to Calais
    May 2006
    You need the adaptor plate to fit the DFI & seperate coil pack setup on the VN. I know this, I have done this.
    Apr 2008
    VN S1
    Jan 2008
    VN S1
    Jan 2008
  15. #15
    Apr 2008
  16. #16
    Vp series 2
    Jun 2008
  17. #17
    VR Commodore V6
    Sep 2008
    Sydney NSW
  18. #18
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    yea i reckon i might just get a s2 one... still running on Zuicider's spare one
  19. #19
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
  20. #20
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    mail it to me hhaha cbf going all the way to joondalup again
    actually don't bother.. i don't know the kms on it anyway.. although my s1 one lasted well past 500,000
    Sam
  22. #22
    VN Exec to Calais
    May 2006
    Smile
    Quote Originally Posted by chinabone2000 View Post
    ok can u explain it bit better and were can i get one wat does it do
    If you want to use 3 Individual coils instead of the 3in1 Setup found in the original VN's, you can. You will have to make sure that you have an adaptor plate (metal plate) that allows you to use (physically fit) the 3 individual coil packs and DFI module to suit in a Series 1/2 VN. Without it, the DFI module (electronic part under coils) will not fit. You need to fit the adaptor plate first, than the DFI module that came with the 3 individual coils, than the coils. The bracket is shaped different to original and has special bolts that come with it.
    I have a couple of these spare, but like others have said, you could probably find some on ebay or buy new.
  23. #23
    VN EXECUTIVE
    Jan 2009
    You can change the Series 1 Coil Pack to anything up to a VX, I just changed my VN Series 1 coilpack to a VX Coil pack with you just need the full coil pack eg. The base and the top, all you need to do is when you unplug the coil pack is check the colour of the insert and get one the same colour and then its a direct swap over. I found it to give me alot more power in my engine aswell. Cheers
    Bull3t
  24. #24
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Picked up a s2 coil pack from a mate a few days ago.. I'll just leave it at that. Got another mate with a set of MSD ones I might offer him some cash for if I feel like it, until then, nothing fancy just an s2 set will do fine.
  25. #25
    VN V6
    Mar 2009
    Hey guys , i have a VN series 1 V6 in my 4 runner im wanting to put series 2 or up to VX coilpacks in it , has anyone got any pics of the adapter plate they have made to mount the DFI module ?
  1. msd coil pack
    By Archers in forum V6 Development And Modification
    Last Post: 31-01-2012, 08:33 PM
  2. coil pack /dfi
    By gold_vienna in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2008, 05:22 AM
  3. VS coil pack
    By mark_1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 06:29 PM
  4. coil pack
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2005, 02:29 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
