Results 1 to 12 of 12
Thread: Starter motor sounds like a machine gun with no ammo
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Default Starter motor sounds like a machine gun with no ammo
    More or less summed it up in the title, but here's the details:
    The car has been off the road for a couple of months just while I fix various bits and pieces on it, I've just done a stack of bits today (harmonic balancer, O2 Sensor, Crank Angle Sensor, thermostat, radiator...). I hooked a battery to it (brand new optima red-top) and turned the key.
    No Joy.
    The starter just keeps on clicking away trying to turn the engine. I can spin the engine by hand with a socket on the balancer so I know it's not siezed. I had my better half have a look while I was in the driver's seat, the engine slowly creeps around a little bit. The alternator fins move
    Anyone had this before? I'm thinking starter motor needs replacing, but want a second (3rd, 4th and 5th) opinion before a rip into it.
    Thanks in advance,
    Michael
    Gravity is proof that nature keeps getting us down.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah sounds like the solenoid is playing up. You can try giving it a few taps with a hammer that might work. I had a similar issue on a vk i got the end cap (where the wires go to) replaced and it was fine after that but it maybe easier getting one from the wreckers
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    So the when you trun the key the starter motor truns the engine but only just whilst its making a clicking noise?
    VN Calais 5L
    Dec 2006
    happened to me in my old car, was a dead battery. obviously you've said you hooked up a new battery so that kinda ruins that theory. is it possible to get a bung battery?
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Mine makes that noise when have flat battery
    Australia. Love it or leave it
    vg ute
    Oct 2008
    SE Burbs VIC
    mouce's Avatar
    Jul 2005
    Cheers guys, I know the battery is good, tested it in another car. I'll chase through all the electrical gremlins then try replacing the solenoid.
    @Pub24/7: It clicks like crazy, and only JUST manages to move the engine around a couple of degrees, can't turn it over.
    I tried the old wrist-breaker technique of throwing a socket on the crank shaft bolt and wrenching on that while my better half turned the key. It REALLY wants to start, but the starter just isn't being nice to me.
    BTW: Just to prove it wasn't the battery, I tried jump starting it. Same result.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    power cable from your battery to starter has finally packed it in. TO test this, charge your battery good and then go to jump start it like usual but put the positive jumper lead right on tthe terminal of the starter and see how she fires up then.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    VP Berlina
    Sep 2008
    I had exactly the same thing on my VP. my problem ended being a flat battery. Even when I jumpered it, it was still doing the same thing. The old battery was causing massive current drain on the jumpered new battery. I had to physically remove old battery. If you've already done that it could be a bad negative connection.
    Thanks to VrWagz1.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    since its been sitting for a while there might be some corrosion on the terminals reducing power to the starter
    VP Wagon
    Oct 2008
    The teeth on the starter are probably worn and slipping when its turning the flex plate. Starters are cheap ($40-$50) and easy to find at the wreckers, so change it and see how you go. Get a VR/VS starter if you can as they are much easier to put in than the VN one (much smaller) and are of better quality, only thing you need to put them on is the bolts that came with it originally, dont use the VN ones. Hope this helps.
  1. starter motor vn v8 - vn v6
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2008, 12:58 PM
  2. starter motor
    By synical in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-10-2007, 07:28 PM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. Starter motor
    By Starion in forum Electrical Wiring / Questions
    Last Post: 27-10-2005, 06:39 PM
  5. VR V6 Sounds like a washing machine
    By *PNK.LDY* in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 05:39 PM
