Results 1 to 17 of 17
Thread: Engine Swap -- Auto to Manual Possible?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Question Engine Swap -- Auto to Manual Possible?
    Hey Guys,
    Was curious to know, im currently on a mission to get my hands on a Series 1 Vn Engine for my 5Spd cos the engine in it is F**ked, the question i ask is; Is it possible to put an engine from an AUTOMATIC gearboxed series 1 vn into a MANUAL gearboxed series 1 vn?
    Cheers.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    possible yes but you'll need to get a flywheel adaptor. Other wise keep loooking for a manual motor
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    social's Avatar
    Nov 2008
    South Aus
    what does a flywheel adapter cosist of? and where can i get and how much will it cost? thanks mate
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    It's a crank adapter from CRS, about $338? i think when i bought it, or a complete custom flywheel for around $600. Only way its going to happen without a crank swap.
    Too bad your in adelaide, i got a S1 manual engine in the garage
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    find a series 1 motor sean as i said lol ... i cant be bothered with making a series 2 motor fit your car
    SIR LS1
    the two ton go kart
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by davecunno View Post
    More of a question of $ then can be botherd or not, crack adapter isent that difficult to put on, 6 bolts and its done.
    The Daily VN T5V6
    355 VN GRP A REP
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    yes but from memory wiring loom is different on s2 and thermostat is on other end of the motor and that still has to be done
    SIR LS1
    the two ton go kart
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    that would be a problem if he was using a S2 engine, but his not
    The Daily VN T5V6
    355 VN GRP A REP
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    CRs also make new flywheels to suit v6's dont know how much they cost
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    mischa the point is we were tyring to find a series 1 engine , cause they cost less than the adapter itself costs
    SIR LS1
    the two ton go kart
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Pub24/7 View Post
    Yeah thats the one i mentioned for around $600 for a custom one to fit a S1 auto engine.
    Well ill take your word on that cause i dont know how much there worth but i know there rare, and that puts the price up to begin with.
    Anyway i was just pointing out that his not putting in a S2 engine in my last post that's all, not meaning disrespect you or anything.
    The Daily VN T5V6
    355 VN GRP A REP
    social's Avatar
    Nov 2008
    South Aus
    Thumbs down
    I have a series 1 engine possibility, which is why i was asking about auto to manual becuase i have an auto series 1 engine i may be able to get my hands on but i wasnt sure if it wud suit a manual transmission.
    I made that clear as the thread question right guys?
    "Is it possible to fit a engine that was from an automatic transmisison, into a car that has a manul transmission?"
    social's Avatar
    Nov 2008
    South Aus
    -- bump --
    Vp series 2
    Jun 2008
    to use a s1 auto engine you need to purchase extra parts to fit it up.
    the back of the crank is a little differnt.
    other option is a s2 engine with harness and computer with manual flywheel.
    s2 up had the same crank on the lot, but it is still different to the s1 engines.
    short answer is no not with out costing a heap extra.
  15. #15
    social's Avatar
    Nov 2008
    South Aus
    so im pretty much after a series 1 manual engine full stop? correct? if im wrong by thinking that lay out my options 1 by 1 plz lol
  16. #16
    social's Avatar
    Nov 2008
    South Aus
    this is such a headf**k can someone please explain it? Ive got one person saying i cant put a series 2 engine in instead, others saying i can, other people telling me i cant put a series 1 auto engine into a series 1 manual transmissioned vn. Im jsut so confused right now.
  17. #17
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Ok, so you currently have a S1 manual VN with all S1 bits and you want to change the engine, thats what i gathered?
    You can do one of the following,
    Using a S1 manual engine:
    1.easy, stright swap.
    Using a S1 auto engine:
    1. Buy a crank adapter from CRS around $300
    2. Buy a custom flywheel from CRS around $600
    3. Change the crank to a S1 type, in other words from your old engine.
    Using S2 onward engine:
    This is proberly the hardest (apart from crank swap) because it involes changing more then just the engine.
    Personal if would be easiest to find a S1 manual enigine anless you find a good value S1 auto engine and dont mind paying for either a crank adpater or custom flywheel.
    The Daily VN T5V6
    355 VN GRP A REP
  1. auto to manual swap
    By goanna_38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2008, 05:38 PM
  2. Auto to manual gearbox swap
    By BANKS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2007, 09:36 PM
  3. SWAP: VN (recent reco'd)AUTO FOR MANUAL
    By saint_matrix in forum Swap / Wanted to Buy / Trade
    Last Post: 26-05-2006, 05:06 PM
  4. want to swap vl turbo for vr v8 auto/manual sydney
    By TT3.8L in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-07-2005, 05:17 PM
  5. Motor and gearbox from auto to manual swap
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-05-2005, 10:52 PM
