Results 1 to 20 of 20
Thread: Exhaust goes quiet
    2001_VXSS's Avatar
    2001_VXSS is offline keepin' it real
    VR Berlina Series II
    Sep 2008
    Default Exhaust goes quiet
    hey all
    im pretty sure cat is stock but from cat back in 2.5'' pipe with 1muffler box at rear wheels. When the car hits about 3,000RPM the noise like goes quite... what can i do to make the noise continue through to high Revs. cos it changes gears around 3,000-3,500RPM and it starting to annoy me when it goes quite at 3,000RPMS.
    cheers
    My Write-Off
    http://forums.justcommodores.com.au/...t-berlina.html
    Originally Posted by hotred View Post
    Will, obviously our checkers game was disrupting the public lol.
    Posted by DVSV8
    we were playing hoon checkers! did you here all V8's screaming every move!
  2. Default
    if you have a v6: sorry to break this to you but the only way to fix this problem is to buy a v8. just kidding. a v6 can be loud, but sounds like arse.
    from your post, i didn't quite get your system. do you have CAT -> MUFFLER -> RESONATOR? muffler is just after the cat, resonator is after the diff. if you have a resonator, remove it. if you don't then you may purchase a new muffler (straight-through) or exhaust.
    Quote Originally Posted by zai View Post
    I am not sutpid
    VT
    Apr 2005
    QLD
    try installing a different muffler. go into an exhaust shop, tell them what you want and they will sort you out.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Why would you want an increased level of noise. If you're not sure if the engine is still running - you can always check the tacho. It works for me !!
    VN Calais 5L
    Dec 2006
    Quote Originally Posted by Benboy View Post
    being a vn exec i doubt he has a tacho
    im gathering from the fact its quite after 3000 that its a v6, my first car had the same problem. straight through cat-back exhaust systems will fix your problem, but dont expect it to sound great.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Quote Originally Posted by Patrick77 View Post
    hey all
    im pretty sure cat is stock but from cat back in 2.5'' pipe with 1muffler box at rear wheels. When the car is under about 3,000RPM the noise is all loud and droney... what can i do to make the noise quieter through normal driving Revs. cos it changes gears around 3,000-3,500RPM and it starting to annoy me when it is loud under 3,000RPMS.
    cheers
    Fixed.....
    EDIT: Also, the problem I have just described is one I am having. Looks like it's time for a new exhaust
  7. Default
    Quote Originally Posted by Philthy View Post
    Fixed.....
    get a stock exhaust, or definitely one with a muffler and resonator! resonator should remove that disgusting sound down low.
    I am not sutpid
    Vp series 2
    Jun 2008
    mate fit the rear resonator make it real quiet.
    also new rubber mounts are a good buy to.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    baaaaaah who needs an exhaust, if you want loud take the whole thing off
    you wont like the attention or your ears bleeding from the drone, but atleast it will be loud
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by levymetal View Post
    Yeah, I do have 2 mufflers but the rear one isn't worth the steel its made from. New one will probably be my christmas present to myself.
    Nevermind me, I just don't see the point of getting an exhaust simply to make as much noise as you can
    VT
    Apr 2005
    QLD
    Exhaust systems are compromised to ensure they comply with laws and standards. If there were no laws or standards in place, then they would be a whole lot different as they would purely be optimised for performance only. Sound 'quality' might go right out the window with some engine types, but some engines would sound downright horny if they only had a couple of feet of pipe lol
    I just realised this is a meaningless post. Thanks for reading it he he he
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    Stock exhaust sounds soo much better than a 2.5 inch pipe on a dead stock v6, trust me. All you will gain is a little more top end push, reduced off the mark acceleration and a annoying drone that can be recognised from a mile away.
    Vp series 2
    Jun 2008
    vp v6 lpg system 70mm throttle body, extractors and no resonator and a kitted auto leaves the local stock vr ss's behind.
    It MUST be the RED paint on the extractors that makes it go hardish.
  14. Default
    Quote Originally Posted by centy View Post
    I am not sutpid
  15. #15
    304 Calais
    Aug 2007
    Up your mum
  16. #16
    2001_VXSS's Avatar
    Sep 2008
    hey ppl cheers for all the advice.
    yes the car is a v6. and she has a nice sounding exhaust which isnt too loud or too quite either just rite. its just that she goes quite at 3,000RPM.. so might trying getting new muffler box. and my exhaust looks like this. CAT - pipe - (at rear wheels) muffler box then straight throught to end. no resinator or tip. so might trying getting new muffler box..
    anyone no of a good place to get a good box? thats not out ragestly expensive! cheers
    My Write-Off
    Posted by DVSV8
  17. #17
    2001_VXSS's Avatar
    Sep 2008
    and YES my car does have a tacho.. im pretty sure is a cluster 2 or 3. im not quite sure on the names of that stuff. im more into the mechanical side of things, not the electrical. lol
    My Write-Off
    Posted by DVSV8
  18. #18
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    just a quick question, i only have standard from car to middle muffle near end of gearbox, (so everyone understands) then 2.5" from there out, and mine is quiet loud from round 1600-3200, and also a vn when ur just cruising round town in an auto it should be changing a lot lower than 3000, id say around 2500 give or take, correct me if im wrong but id hate it if mine was changng at 3000rpm when cruising
    If you do things righ people wont know you have done anything at all...
  19. #19
    VT
    Apr 2005
    QLD
    lol and you still call it a mufflerbox? he he he
  20. #20
    2001_VXSS's Avatar
    Sep 2008
    Quote Originally Posted by VT-565 View Post
    yeah i can still call it a muffler box... hehe
    My Write-Off
    Posted by DVSV8
  1. 3" Exhaust Really Quiet after Pacies
    By vagure5 in forum V6 Development And Modification
    Last Post: 22-02-2008, 09:53 AM
  2. vl vers vn not quiet sure
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 03:15 PM
  3. quiet
    By executive_power in forum General
    Last Post: 16-05-2006, 07:27 PM
  4. lound then quiet
    By bensta in forum Car Audio
    Last Post: 29-10-2005, 11:03 PM
  5. Quiet Efficient Muffler?
    By ozute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2005, 03:48 PM
