Results 1 to 16 of 16
Thread: help! oil pump problem
    vp executive
    Sep 2008
    Default help! oil pump problem
    well heres the story i rebuilt the lower end of the 3800 motor and put it all back together n just fired it up and it was tickin like crazy so i shut it off for a few min then tried it again and the oil light went off right away but then very soon came back on and same issue with the engine, just too noisy.
    is there a quick fix to get the oil pump goin again? or do i have to change the damn thing?
    vnss
    Jan 2005
    s.e melb
    ive always read that they can be packed with vasoline to get pressure on start up
    Vp series 2
    Jun 2008
    3800 don't need to be primed.
    take the filter of and make sure it is pumping.
    did you touch the oil pump in the front housing?
    vp executive
    Sep 2008
    didnt touch it except to line it up for the crank and when i did that i spread my first 2 fingers to turn it to line it up
    Vp series 2
    Jun 2008
    v6 oil pumps don't need to be primed so not sure what has happened.
    did you check clearances before putting it back together?
    what did you use on the bearings before you reassembled them?
    did the oil holes line up with the new bearing shells?
    vp executive
    Sep 2008
    it was just the rod bearings i replaced i put them in properly and smothered them in grease b4 i put the rod caps on and even the lifters are tickin badly i think im just gonna have to replace the timing cover would anyone have a cover with a good pump in it?
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    if your oil pump is not working caudsing low oil pressure than the fuel pump will be disabled and your motor wont run at all.
    and yeah did you use proper white grease when installing the bearings in the bottom end? could it be a blocked pickup? what was it like when you took it out?
    vn calais, vs clubsport #137
    Jun 2005
    has it got oil in it .
    as stated before take your filter off and give it a crank, see how much flow u are actually getting, are u using some osrt of run in oil?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Put a pressure gauge into where the oil pressure sender unit start it and check you got pressure you should have 40 psi at idle and up to 80 psi at high revs. Sounds like if its ticking your not getting up to the top end.
    If you didnt disassemble the timing cover and oil pump gear drive then i doubt its an oil pump problem
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vp executive
    Sep 2008
    stock size bearings, the same grease you use for wheel bearings(clean of course), shell helix 20-w50, and i cleaned the pickup b4 i reassembled the pan
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    if it had oil pressure before and u havn't played with it ,then its not the pump
    Vp series 2
    Jun 2008
    Quote Originally Posted by vnv8driver View Post
    Dead wrong.
    the oil pressure sensor ALSO provides power to the pump.
    This is what keeps the pump going a few seconds AFTER the engine has stopped and also allows the pump to operate IF the pump relay fails.
    it IS NOT a low oil cut out, that would be just silly.
    I would rather blow and engine then have a car parked over train tracks when the 9 oclock arrives.
    to prove this point go and un hook you oil pressure sensor and start your car.
    It will crank and start like normal.
    now to the problem
    maybe a little gasket goo in the oil gallery from when you had the covers off.
    vp executive
    Sep 2008
    nah cleaned it n re checked it b4 i put it back together. im gonna try to put a funnel to the presure sensor hole and pour oil into the pump while i rotate the motor over backwards by hand. it does seem feesable that its just not priming by its self
  15. #15
    vp executive 92
    Oct 2008
    newcastle
    my money is on the pick up. its a common problem. Best presure test the pump first if ya got plent of pressure take off ya rocker covers start the bitch and look for oil,if you see none then again my money is on the pick up
    good luck
  16. #16
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    this is how i fixed the same problem
    primeing vp v6 oil pump without pull down mod
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. Potential VX Water Pump problem
    By Nuffy in forum General Discussion
    Last Post: 28-04-2008, 01:57 PM
  3. Fuel Pump Problem?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:46 PM
  4. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
  5. VX Excex fuel pump /LPG problem
    By tiges1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2006, 06:56 PM
