Results 1 to 10 of 10
Thread: vp calais fuel guage problem
    VR Executive
    Jan 2008
    Default vp calais fuel guage problem
    hi guys,
    the fuel guage on my vp calais just died. the gauge doesn't move/respond and the distance to empty etc has stopped working as well. What should i check, fuses, sender etc? if it is the sender that needs replacing is it hard/expensive? the car was low on fuel, light and alarm came on. went to the servo and put $20 in and then nothing worked since.
    thanks
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    On the VN it's the light blue wire from the tank sender to the cluster that give you the DTE.
    I'd get under the rear of the car (at the tank sender) and check the sender/wire contact for corrosion.
    and 3 Dangerous non ABS VN's
    VR Executive
    Jan 2008
    VR Executive
    Jan 2008
    it's not only the dte that doesn't wotk but guage doesn't either.
    will check the contacts.
    thanks
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by vl_davo View Post
    thanks
    Gauge and DTE power from the same wire I think. So no DTE and dead gauge = contacts or cut wire.
    ThisNameIsTaken's Avatar
    ThisNameIsTaken is offline Colossal Moron
    the ....
    Nov 2008
    Shenzhen China, NSW Wagga Wagga
    could also be the sensor has died dunno if its common but if both are gone its prob the wire or the sensor
    [SIGPIC][/SIGPIC]
    VR Executive
    Jan 2008
    hi,
    just checked the wires and the contacts and they look ok. any idea how much a sensor is? also do you just un bolt the old one (small bolts) from the tank and bolt the new one in?
    thanks
    88GreenVN's Avatar
    Jun 2006
    To discover my wire had been cut (due to rear end accident) I ran a wire from the sender to the plug under the dash. Lit up the DTE so I ran a by-pass wire to fix the problem.
    As for removing the sender. Cant help with that.
    the ....
    Nov 2008
    88GreenVn
    has got the idea just look up what one you need to get properly and connect a lenth of wire to the connector on the sensor then to the DTE in the car and hope it works if not then as far as i know they are built in fuel sensor senders in holdens are they not? if so its a new sender sensor unit and most times they just unscrew at the top but tank might need to be removed not sure never worked on a holden but trouble shooting wise. connect the wire up and see what happens
    [SIGPIC][/SIGPIC]
  1. Calais Fuel Guage
    By Ronaldw in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-01-2008, 07:40 PM
  2. Average fuel level problem on Vs calais
    By L31GH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2007, 05:59 PM
  3. Fuel Guage Problem Fixed Possibly
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-10-2006, 09:41 PM
  4. fuel guage problem
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-11-2005, 10:14 AM
  5. Sticky fuel guage - the common problem
    By brettkp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2004, 11:46 PM
