Results 1 to 18 of 18
Thread: aaaahhhhhhhhhh
    vp executive 92
    Oct 2008
    newcastle
    Default aaaahhhhhhhhhh
    ok guys and girls im needing some help my vp is making a "TAPPING" noise from the top of the engine my first thought was lifters so i changed em nope noise still there oil pump is fine oil pick up good no error codes the noise comes and gos and is starting to bug the **** outta me
    PLEASE HELP
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    it's not the balancer or something? they seem to make a rattling/tapping noise when the rubber cracks/disappears.
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    injectors might be getting old and noisey.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    [url]http://.codoes it soind like this
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Wow, AWESOME thread title mate ^_^
    Could be valvetrain rattle, or a noisey injector.
    The 1972 HQ Kingswood
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Timing chain tensioner can make the hollow alloy sound under light acceleration
    and 3 Dangerous non ABS VN's
    vp executive 92
    Oct 2008
    newcastle
    i had given the balancer a thought but not the injectors .......thanx guys
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Get a long flat blade screw driver and rest it on each injector and stick your ear on the handle end to amplify the sound, if the sound matches then you may have fuond your issue.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by 88GreenVN View Post
    they make a bad noise noise, i broke one on my v6 and spun a few big ends/ main bearings... i cant listen because im at work but get a big screw driver and use it to listen to the motor (you the blunt end on your ear) you can hear inside the motor
    Sep 2008
    Morton's Avatar
    May 2006
    Anything long and metal will do I've used breaker bars, a crowbar, a big spanner, an old aerial...
    But a big metal screwdriver is best, and press the handle into your ear
    Sep 2008
    i had a mental image of some one pushing my head in to the screw driver and walking around with it lodged in my brain like frankonstain.
    Morton's Avatar
    May 2006
    lmao, that's a fantastic mental image mate If you want to be a wanker, you can go out and buy an actual stethoscope... I guess that would be kind of cool. I want one now...
    vp executive 92
    Oct 2008
    newcastle
    well guys i put the screw driver to all the injectors and they are ****ed lol replacing them tomorrow
  15. #15
    vp executive 92
    Oct 2008
    newcastle
  16. #16
    Morton's Avatar
    May 2006
    Just curious, were they ****ed because they were ticking? Because they're all meant to tick a little bit
  17. #17
    VP Executive R-spec
    Jan 2005
    They're actually ment to tick really loud :! expecially with a fine tuned screwdrivescope on them
  18. #18
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    yea they tick loud when listening to them through the screwdriverscope or gardenhosescope, when trying to find engine ticking, always ALWAYS check your exhaust connections 1st, 80% of engine ticking is actually exhaust (well maybe not 80% that was a made up stat)
