as the title suggests im trying to find the rating of my injectors 0280 150 926.
cheers
You looking for this information:?
fuel injector flow rates
0-280-150-926
136.1
43.5
18 lbs and 43.5 psi
great i got **** injectors
cheers crazy biker
No problem.
zuicider what are you trying to acchieve with this? higher flow injectors?
heres a hint for you, toyota cressida injectors :P, if you can find them toyota supra injectors (7mGTE)
7m's are 440cc and top loader fuel injectors, failing that 89 magna injectors (creamtops, 706s are 21/24lb?)
fit creamtops to your v8 (if your bt1 is a 8 :P)
years go before i was on jc i picked up a set of v8 recond injectors that suited the vs vt hsv range *prolly their selling pitch* cheaper than i could get a set of vn series one v6 ones, its only now im trying to get my head around it before i either wreak the car, sell it complete or finish it
VN injectors are only a lil bit more 18.55, VR is like 18.25. when getting injectors from a magna can it be a newer magna like a TE TF TJ? V6
~ VN POWER ~ Click the scales
