Results 1 to 6 of 6
Thread: i need help
    vp wagon
    Nov 2008
    Default i need help
    i need help i own a vp wagon 92 ive been having a few problems and i know nothing about them first it was the fuel pump thats fixed then it kept dieing i changed the filter too but still nothing so we canged the coil pack tht didnt help its still dieing i was thinking it could be the crank angle sensor but antill 4days ago i didnt even know my car had one so any help would be good
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    you really need to diagnose what kind of problem you have, I would suggest checking for spark 1st, then fuel, then compression and so on
    vp wagon
    Nov 2008
    thanks but all this still dont help me im an old skool holden girl i wish my boyfried knew what he was going on about then maybe i could drive my car around
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by hartsc View Post
    id be checking compression first,
    mechanical > electronical..
    but it wont be comp... did u change the entire coils? ie DFI moduel
    vp executive 92
    Oct 2008
    newcastle
    id also have a look at ya injectors mate and yeah dfi modules have a tendency to play up and cause many many probs
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    how is it dying exactly, if it 's driving for a bit then conking out and then it won't start for a while, it's prolly the crank angle sensor, you can check for this by splashing some water on the crank angle sensor after it won't start. if you search the forum you'll find the location and info on it.
    also is there a engine warning light lit up on the dash? if there is do a check for error codes.
    here's a link for how to do that. Checking your Computer for Faults (VN - VP)
