Results 1 to 16 of 16
Thread: VN Manual Conversion What parts are needed and will a t5 box out of a ford fit in vn
    VS5lTR's Avatar
    VS5lTR is offline MTX KID
    VS
    Nov 2008
    Default VN Manual Conversion What parts are needed and will a t5 box out of a ford fit in vn
    I am about to buy a vn and what parts will be needed to do the conversion
    squiblex's Avatar
    squiblex is offline UNSEEN
    VK 308
    Nov 2008
    SA great mate!!
    u need a flywheel and clutch and pressure plate, pedal box, clutch cable, speedo drive thing, and tail shaft. i think thats it
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Series one or two?
    V6 i guess?
    If you do a search there a few threads with a complete parts list for V6 and a few for V8.
    aZk.
    VS5lTR's Avatar
    VS
    Nov 2008
    VS5lTR's Avatar
    VS
    Nov 2008
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'm not sure about the Ford T5 box. The input shaft is probably a different length for starters.
    I know that a V8 T5 won't work on a V6 T5 for this reason. And the gear ratios are different.
    The 1972 HQ Kingswood
    May 2005
    .....SE Burbs
    Quote Originally Posted by Morton View Post
    as far as i know, the ford t5 is identical to the holden... so there shouldnt be an issue there. You can use a 6t5 in an 8 by machining the input shaft down... but 8->6 wont work unless you have a new one made up.
    SERIES IS VITAL! Series I's had differnt engines for each transmission... well the crank was different so you might as well had a diff engine. I think it was CRS who made an adapter plate for the SIAuto to fit the 8bolt manual flywheel... the auto uses a 6bolt flywheel...
    I believe the manual starter is a v8 issue? not a v6.. i didnt swap mine anyway. Youll need different headers as the auto ones wrap differntly around the trans. Tail shaft, which you can make from a wagon appharently...
    Wiring harness from box to loom, box, shifter surround (metal and cosmetic), clutch, cable, pedal box. ECU is a myth, auto->manual is interchangleable...
    aZk.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Please Read this How to has all the information you need
    The complete Vn-Vr Manual Conversion Guide.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VS5lTR's Avatar
    VS
    Nov 2008
    depends who you ask some people say u dont need manual computer and u dont need manual starter motor
    Black VN MANUAL
    Feb 2007
    Top of Vic
    You dont need the manual computer i have an auto one on mine, and you will need the manual starter motor its smaller and the auto 1 will not fit.
    ~ VN POWER ~ Click the scales
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    auto one will fit on, but it wont start the car. Found that one out the hard way.
    Another place that sells flywheels is holdent, it was the only place i could find a series 2 flywheel, i rang crs and they didnt have any for a month, plus it is a flywheel not an adaptor plate. Bit pricey though.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Morton's Avatar
    May 2006
    Yeah, those things can cost a LOT of money >_> was it a billet flywheel? Just curious what you'd be getting for the price
    And yeah, as everyone's said, you can use the auto computer no worries. I'm running an auto computer and tune in my T5 VQ.
    Jun 2006
    Western Aus.
    Quote Originally Posted by azkwazere View Post
    as far as i know, the ford t5 is identical to the holden... so there shouldnt be an issue there. You can use a 6t5 in an 8 by machining the input shaft down... but 8->6 wont work unless you have a new one made up..
    Why would you get it machined? By the time you've paid for machining, it would of been cheaper to get a new one from TTC (Tremec). Difference in ford/holden/v6/v8 boxes are the gear ratios, input shafts and bearings.
    Hot Lap Motorsport
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
  15. #15
    VP Executive R-spec
    Jan 2005
    And it's a different shape case I beleive, there's info on Dellows website about this, the guts of the gearbox is the same but it wont easily go in
  16. #16
    Morton's Avatar
    May 2006
    For the cost and time effort of stuffing around, it's almost always going to be cheaper to get the right box, unless you can pick up any particular T5 for free.
  1. FS: Vn Vp Vr Vs Manual Conversion Parts
    By mad13b in forum Parts And Other Items For Sale
    Last Post: 01-02-2007, 01:06 PM
  2. WTB: Manual conversion parts for VK.
    By VRSS in forum Swap / Wanted to Buy / Trade
    Last Post: 14-05-2006, 09:25 PM
  3. PLEASE HELP: Manual wiring conversion help needed!!!
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2006, 10:53 PM
  4. List of parts needed for V8 into VK conversion.
    By Jamie W in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 01:57 PM
  5. FS: 5L Manual conversion parts
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 13-09-2005, 09:35 PM
