Results 1 to 9 of 9
Thread: Windscreen swapping?
    VN S1
    Jan 2008
    Default Windscreen swapping?
    I wanna swap my brand new windscreen from my vp to my vn is it possible without breaking it and what type of glue do the windscreen places use to hold them in?
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by needwork2-4fillhabbit View Post
    The best method I found for taking windscreen's out is try and poke a small steel rod through with some fishing line attached, them pull back and forth on the fishing line until you have gone right round the window then get you and one of your mates to sit in the drivers and passengers seat with your feet up over the dash on the windscreen as even as you can with all 4 feet (yours and your mates) while someone on the outside to stop it popping out really quickly and smashing. its not easy but if your careful and apply even pressure it does work.
    Hope that made sense, as for the glue if you goto your local auto store they'll have something to help you, there are many many products that do the same job.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    ive always used guitar strings to saw through the urethane in the same manner as hartsc said but once youve got all the way around the screen should lift out with no force needed providing youve cut around all the way
    you should be able to peel the old rubber out without breaking it and then re use it and one tube of stikaflex polyurethane is all you need to glue it back in just make sure both the glass and the frame are both clean first
    im not admiring your car im looking in disgust
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by HDT_aero View Post
    Guitar string would work perfect, time to hone my skills.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by Zuicider View Post
    sikaflex is the glue of choice
    don't sikaflex have a range of products? is that the actual name or a brand name?
    EDIT: don't worry its called 'sika tack' new drive formula.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    hmm make suree ya keep a good grip on that windscreen - had mine taken out (all in one piece) only for one fella to drop it after it came out the car and put a massive crack in it - grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr had to be replaced 240 for a newie
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    yea sorta hit and miss with swapping screens .. tryed a couple of times and broken a windscreen a few times lol
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    VN S1
    Jan 2008
    Ill have to go 'busker hunting' and grab a e string, ill give it a whirl and if it breaks no biggy had to get it replaced anyways if the vp wasnt shagged. Thanks for the tips!!
  1. Seat Swapping
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2006, 06:03 PM
  2. Swapping cam in VR VS V6 ?
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 02:36 PM
  3. Swapping VR bits
    By Carl_B in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2005, 11:34 PM
  4. swapping motors need help
    By holden man77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2005, 02:47 PM
  5. Swapping Struts.
    By SV-3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 04:42 AM
