Results 1 to 19 of 19
Thread: 4 cyl vn diff strong?
    vn executive s2 v6
    Jun 2008
    Default 4 cyl vn diff strong?
    hay all this may be a stupid question but does anyone no if the old 4 cylinder diff are the same as 6 cyl diffs but with different gears? like are they strong enuff for a 6? reason is i have one and im sure i read somewere they have 4.11 ratio?
    vn calais, vs clubsport #137
    Jun 2005
    which 4cyl diff are u refering to, what motor, i know the pintara diff centre is the same as the commodores and uses a 4.11 gear ratio with a 4cyl up front powering them..
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'm really not sure. i think they are BW diffs but not sure on the specs. i know the hubs have a different stud pattern because then the inlaws tried to fit the wheels from there crashed BT1 onto the 4cyl VN they didn't fit properly. i too would like to know what ratio they have because i'm looking for some gears for a future project
    Body by Holden, Soul by Brock
    the Legend will live forever
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by immortality View Post
    They are 4.11's, same as a pintara.
    Selling FG G6E Turbo and buying a N/A Supra
    vn executive s2 v6
    Jun 2008
    yea im talkin abowt the nz spec 4 cyl vn, my one has an opel motor in it, and the stud pattern and spacing is the same as the v6 diff cause im using the wheels off the 4 cyl on my v6 now.
    i dont realy want to change diff over and it just ****s itself straght away.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by jonboy View Post
    me too. the inlaws have one. we put a wheel from the 4 banger on the BT1 to move the wreck but it didn't fit (without a little filing) they don't want me to pull it apart to find out the ratio however.
    if you can tell me what RPM your at 100km/h in 4th gear i should be able to calculate the ratio. it doesn't really matter what speed as long as it's in 4th gear as it's normally 1:1
    vn executive s2 v6
    Jun 2008
    hay immortality ill have 2 c if ican get the old 2 ltr to run at sum stage, (it needs a few things done to it so it can be driven 1st)
    have you got your commputer all working so you can burn memcals yet?
    Apr 2006
    Auckland NZ
    yep, got all that sorted.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Not 100% sure as I don't know alot about diffs, but I've heard that the NZ 4 cyl commodore is a 4.11 but 2 pinion (if that makes sense to anyone)
    Apr 2006
    Auckland NZ
    Quote Originally Posted by hartsc View Post
    could be, the standard BW 78 is a 4 pinion setup. they used 2 pinion centers in the VL 6's so it could have been carried over from there and just a ratio change for the crappy 4 banger engine. i wonder what ratio diffs the 2ltr 6 cyl VL's have?
    vn executive s2 v6
    Jun 2008
    im pretty sure the vl 2ltr has 3.7 ratio
    how much to burn the sv3800 tune so i can run an o2 sensor? or do you rekon i should try an get an ozy foam tune?
    my 2ltr needs has no reg no wof no exhaust no steering wheel an no back wheels so might be a bit b4 i take it for a drive.
    Apr 2006
    Auckland NZ
    doing the tune is simple (and cheap) pm me. do you have a O2 sensor hooked up? with the SV tune you will need to run 95ron fuel
    another way to check the ratio in the 2ltr diff is to remove the diff cover and see what numbers are stamped on the outer circumference of the crown wheel. should have serial number and ratio. what code is stamped on the build plate for the diff?
    vn executive s2 v6
    Jun 2008
    no i dont have an o2 sensor hooked up (just got the cable hangin down bellow throttle)
    this should incress performance and fuel economy, correct?
    i will check my diff for the build plate and ill remove the cover as well in the weekend and let you no
    cheers
  15. #15
    Apr 2006
    Auckland NZ
    cheers
    no point getting a tune to suit a O2 sensor until you fit one. will improve economy. the tune itself will give so more go go go. let us know when your set. where abouts are you?
  16. #16
    VN Berlina 2L
    Oct 2008
  17. #17
    vn executive s2 v6
    Jun 2008
    im in dannevirke, if i plug in an o2 sensor without the sv tune will it still run the same?
  18. #18
    Apr 2006
    Auckland NZ
    yep, will run fine because the temp setting in the standard tune for the O2 sensor is set high to the ecu deosn't use it and the fault codes have been disabled for it also.
  19. #19
    Apr 2006
    Auckland NZ
    Quote Originally Posted by KnobMuffin View Post
    I just read in my owners manual that the ratio is 4.11
    cheers mate. you got any pics of your ride?
  1. Strong Smell - Diff Oil
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2008, 06:37 PM
  2. 5.0 on LPG with very strong petrol smell
    By VS Callahan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 01:57 PM
  3. vs v8 manual strong?
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 12:24 PM
  4. be strong honey
    By bazcom in forum Jokes/Humour
    Last Post: 24-03-2006, 09:12 PM
  5. Strong Bad!!!
    By INSINR8R in forum Jokes/Humour
    Last Post: 09-03-2006, 11:17 AM
