Results 1 to 2 of 2
Thread: Window won't go back up!!! (VP Berlina)
    CLE
    CLE is offline
    Mar 2005
    Default Window won't go back up!!! (VP Berlina)
    Hi, I have a '92 Berlina LX with a driver's window that doesn't want to go back up. It happened today when I had it the whole way down and tried to put it back up, but it didn't move at all. I've got it to go back up an inch by hitting the inside of the door, but it only randomly does the trick. I've had the car for a while now and everything has been fine up to now. What should I do? How do I remove the interior door trim?
    I hope it doesn't rain tonight :\
    Chris.
    CLE
    CLE is offline
    Mar 2005
    Ok, well I've had a better look at the situation. When I press the button for the window to go up, the interior lights don't dim a little like they do when I press the 'down' function (taking battery power). I'm thinking that the switch may be the problem (maybe dirty contacts). If so, how to I pop it out to check the underneath?
    Thanks.
  1. back window just xploded
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2008, 02:22 PM
  2. back power window not going up
    By nickmarlow1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2008, 10:55 AM
  3. Rust around the Back Window
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2007, 05:51 PM
  4. Laws on back window
    By russface in forum General
    Last Post: 11-09-2006, 09:10 PM
  5. back window
    By SUSPECT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2006, 05:41 PM
