Yes once again the VN is giving me dramas. Today I was cruising along as usual and the car shuddered and stalled. I went to start it again and it started immediately and seemed to idle fine. I then had it stall on me two more times before I got home. When I got home I looked at the engine and noticed coolant all over the motor. Found out that one of the hoses was badly perished and leaking. Also noticed that the motor was incrediblely hot. The temp however never went above the first mark on the gauge. Would a leaking coolant cause the car to stall?
Get a new temp sensor asap (ecu one) not gauge. If the engine has been getting real hot - not good. Has it been loosing lots of coolant lately?
and 3 Dangerous non ABS VN's
You have 2 temp sensors. If the engine is super hot and gauge says cold = problem.
Coolant leaking for the first time would be unlikely to be the stalling issue.
Start giving the wiring a good old wriggle while the car is running. If its a loose wire it will stall. ECU wires. DIF wires earths and CAS.
coolant in the back ofthe cas maybe.
v6's run BLOODY hot
normal running temp is mid 90's damn near boiling and when you work them hard they go over boiling, that is why the hold so much pressure.
Hope the CAS isnt stuffed. Its brand new. Might test the coils and DFI tomorrow. It was a very hot today and I did give the VN abit of a hard. Could this have possibly damaged the CAS and DFI/Coils?
Well I have to admitt something. I was down a back industrial road and I did give it some when it gave up and stalled all of a sudden and it was a very hot day. Car started straight away so it cant be the ECU or CAS. Maybe DFI/Coils?
You do not have 2 temp sensors, please don't think that. You have a Temperature Sensor, and a Temperature Sender. The Sender is for your gauge and gauge only, and the sensor is for your ECU to know temp.
Also not sure exactly all the details, but look into your Crank Angle sensor. It could be playing up, especially if it got excessively hot. (hot water). Make sure all earth and power cables to battery and alternator are also in good condition and sercured tightly.
Okay thanks. Ive just changed the Crank Angle Sensor so that shouldnt be the issue and when the car stalls it starts straight away.
Ive changed my theory on the problem. Fixed a leaking coolant hose and the car still stalls. Think its just coincidence that the hose blew when the car started stalling. Dont think its a overheating problem but what I think it is, is a fuel issue. After fixing the hose the car seemed fine, so I filled it up and took it on a surf trip with some mates and travelled around 380 kms without any problems with a loaded car. On the way home though after the trip and unloading everyone and everything the car stalled. I noticed that my fuel was approaching empty. Just as last time when it stalled, I didnt have much fuel in the tank. (Mind you, enough though to make sure I dont kill the fuel pump) Only problem Ive been having is that it struggles to start now and then. The motor cranks fine but it takes about two go's most times to get it started and what I find is I can help it start by pressing the accelerator while its cranking. Thinking its a fuel pressure issue up front. The fuel pump is brand new as well as the fuel filter and fuel tank clean, so thats not the issue. Thinking it could be the injectors or fuel regulator. Any thoughts?
Thanks so far guys![]()
Just a question. How do I know for sure that I have a blown head gasket? I have a idea that could possibly be the problem
Well.. it depends on how the gasket has blown. If you were losing a heap of coolant, yet there are no leaks that you can find, it might be a head gasket. Borrow a compression tester and crank the engine over.. if one cylinder is way down on the others, there's your problem. Have you had the cooling system pressure-tested?
