Alrighty, my Oil Pressure gauge came in today, and I plan on installing it as soon as possible.
I originally wanted to use a T-Piece to keep the existing sensor for the idiot light, but thought, it'll be more of a drama.
So I thought, yeah, I'll remove it. Then I heard someone saying that the oil pressure sensor sends data to the ECU to keep the fuel pump going, and that it IS needed, is that true?
But just 5 minutes ago, I unplugged it from the sensor, and started the car, and it didn't stop, nor did the idiot light come on.
So 2 questions;
1. Does the sensor work in a backwards kinda way. When it sees an open circuit or low voltage it shows high-pressure?
2. Would it be fine just to remove the existing sensor and put in my new sensor for the gauge?
Thats a good question mate, i've never heard of it being needed but i'm not 100% sure so i wont just tell you what you want to hear, i recommend just givin a pro a call and ask about it.
VP's ARE THE BEST
it will run without the factory oil pressure switch plugged in. yes the fuel pump is also switched through the oil pressure switch (you'll note when you turn the engine off the pump runs for a few seconds more....before stopping) the switch doesn't signal the ecu. the ecu has it's own signal for the fuel pump relay (thats what runs the car when you unplug the oil pressure switch and what primes the fuel pump when you first switch on the ignition)
you can run without factory switch but i don't recomend it. if oil pressure suddenly plummets you mignt not notice if your not looking at the gauge, however you are more likely to spot a red warning light popping up on the dash.
Body by Holden, Soul by Brock
the Legend will live forever
yeah what he said.
another reason to try to keep the original sensor is that if the fuel pump relay dies then the pump will get power via the oil pressure switch so you can keep driving.
But shouldn't the light atleast indicate it with the Oils idiot light?
Or is it as I said in my original post; An open circuit means it's high pressure?
Yup.
...and after an oil change, it's on for a second or two as the oil runs through.
ive had mine disconnected on my vs for a while now and havnt had any probs, as for people saying its still better to have the factory switch so you still have the engine light i dont see the point cause your gauge is gonna show the oil pressure falling where as with the switch it will only show up when youve lost all oil pressure
well considering my gauges are on the A piller i would notice any difference in oil pressure which would show up way earlier than the little red light lol, might be different for people who mount their gauges under the radio
ok here is a possibilty. you have a small short in the wire so check them for continuity.
also try another ecm incase it is a mod someone has done on your car.
also if ever in dought about the pressure gauge then replace the sensor to be safe, it's only about $20
It's not the wire. It works after an oil change. I've said that.
It's not the ECU or any mod. First, look above, second, the car is COMPLETELY stock standard.
No. With it connected, after an oil change it will.
I'm saying I disconnected it, and started the car. No light.
But theoretically, you'd think if it was an open circuit, the ECU would engage the warning lamp.
