i have a 93 vp and the front of the water pump spin(the bit where the belt goes) could i fix the unit or be better off buying a new one.looking for the cheapest way to fix as only going 2 b a work car.any help would b appreation
The only fix is to replace it. It's not expensive or difficult (provided you don't break a bolt or two.) Try a search on here there should be plenty of posts on how to do it and bleed the system.
The 1972 HQ Kingswood
ok just checking
you have a water pump leak of noise?
It's not the black pulley out front that has been bent of something?
i was wondering were the wires go for the power windows from the fuse box vp93,in have power at fuse box but not at controls or window motor any help would b helpfull
under steering column where fuses are but more under steering wheel is a small black box thatis your power window control box, wiring from there goes under the stereo to you power window controls.
thnx vt brrrlina will try in morning
if i have power goin into the power window controll box but not coming out do i replace the box?are these expensive? thnx mate
found out that pully was the air con compresser pully(bottom right pully) is this correct?should it spin at all?thnx fellas
the pully should always spin on the aircon - its only when its gassed and aircon button is pressed that the clutch is engaged to spin the inside part of it r ya aircon - so yeh it should always spin where ya belt is, umm if ya got a multi meter its easto test ya power windows the button controls just pop out ya dash bit and u can check voltage onthe contacts underneath it when youy press the buttons
no voltmeter only test light
would the central locking wiring b conected to elec windows 2 as central not working either
