Results 1 to 5 of 5
Thread: correct way to bleed vn v8 radiator
    vn 5.0
    Apr 2008
    Default correct way to bleed vn v8 radiator
    hey guys and gals just wandering if anyone knew the correct way to bleed a vn v8 radiator
    cheers
    VP Executive R-spec
    Jan 2005
    Who knows but my way is, pour in coolant, rev engine (coolant drops), pour in more, rev engine (coolant drops) pour in more (coolant doesn't drop), drive away
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by greenfoam View Post
    I let the thing idle but same theory - keep doing it and shove my finger in and keep repeating until I feel warm coolant (means the thermo is open).
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    LMAO, thats about the gist of it. Except im usually not in a real hurry to drivaway at the finish
    Reaper
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Same again After just refilling the system, most of the air is trapped after the thermostat in the upper radiator hose. As such, I find it helps to jiggle and squeeze the hose and encourage the air to move out to the radiator cap.
    Aside from that, just fill 'er up 'till it stops dropping
    The 1972 HQ Kingswood
  1. car running to bleed radiator?
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-07-2008, 09:51 PM
  2. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  3. where is the bleeder screw to bleed the radiator
    By vl rb30 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 08:37 PM
  4. VT radiator bleed valve
    By Fiddler100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 09:06 PM
  5. Make it Bleed
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 04:37 PM
