Results 1 to 16 of 16
Thread: only one black spark plug
    HSV472's Avatar
    HSV472 is offline i just got one
    hsv vr clubsport
    Jun 2008
    s.e melb
    Default only one black spark plug
    ok about 2 mounts ago i blew the head gasket but befor that my passenger side last plug was always coming out black all fixed now but my spark plug keeps coming out black
    its not oil on it its black carbon
    what would cause this?
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    according to the gregories manual
    black plugs can be caused by excessive oil consumption or incorect plug type
    also says plugs in this condition are generally not firing
    spark plug with burnt electrodes due to incorect plug type loose plug or engine running to hot
    cracked plugs from age or using to much force
    HSV472's Avatar
    hsv vr clubsport
    Jun 2008
    s.e melb
    ah ok
    could a bad /old rotor cap cause this(only one plug)
    or a bad injector?
    May 2006
    Perth, Western Aust
    have fun changin that ive had massive probs with mine as of late and im pretty sure the rotor was the problem - but damn gettn that dizzy cap off......
    vn calais, vs clubsport #137
    Jun 2005
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    could be a leaking valve stem seal on that cylinder , or piston rings perhaps ? Does it burn much oil ?
    HSV472's Avatar
    hsv vr clubsport
    Jun 2008
    s.e melb
    VP Executive R-spec
    Jan 2005
    I had dodgy injectors do this a couple of times. I just throw the injector from the rich cylinder away and put another one in
    VP Exec
    Jun 2005
    Quote Originally Posted by greenfoam View Post
    Might be worth swapping the sus. injector with another cylinder and see if the Carbon'ed up 'plug tracks the injector first though.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    if you do need to do the rotor I wrote a how-to on it.. should be able to find it in that section somewhere..
    edit: found it
    5L EFI - changing the distributor cap and rotor
    WTB: mulberry VN interior parts
    Feb 2004
    Quote Originally Posted by vpcalv8 View Post
    hi, could be low on compression, but my bet is non firing/ intermittent firing plug and or lead .. maybe even coil pack ???
    mark k
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    flat black is un-burnt fuel ("carbon") check comp, if comps ok then check the dissy cap dissy cap ok swap another injector for this one and see if it still does it
    Jun 2005
    Quote Originally Posted by krawczuk View Post
    mark k
    his car is v8.
    HSV472's Avatar
    hsv vr clubsport
    Jun 2008
    s.e melb
    well this week im going to buy new dissy cap rotor button and a new injector
    and the comp is perfect
    leads ,plugs are new but it was doing it befor i changed them anyway
    could it be one of the valves
    or
    lifters on that cylinder?
  15. #15
    VP Executive R-spec
    Jan 2005
    Unlikely to be anything other than the injector if the compression is normal, I watch my plugs all the time and like I said I've replaced a few over the last couple of years that have gone bad. It may not seem a common problem but I bet it is. Just that no one else cares
  16. #16
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    haha jason I don't even know how my compression is I've never had a check on either car.... maybe something i should look into
  1. spark plug gap
    By mildewmatt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 03:49 PM
  2. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  3. Spark Plug Gap???
    By markc3012 in forum V8 Development and Modification
    Last Post: 26-10-2005, 06:15 PM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. Spark plug gap???
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2004, 04:14 PM
