Results 1 to 4 of 4
Thread: 89 VN gearbox/engine/??? issues
    VN Executive S1
    Nov 2008
    Default 89 VN gearbox/engine/??? issues
    Hi,
    Just had a second hand installed - had 140,000 on it. Drove beautifully for maybe 1,200km, shifted well in every gear, under full acceleration it performed well.
    Just today when I went to start the car it backfired and part of the air box blew off. I continued to try to start it, and it did (with accelerator pumping) and it sounded like it was misfiring/running on less than 6 cylinders. I let it sit, stuck the front back onto the airbox, and started it - ran fine.
    No problems with the motor after that. After driving for maybe half an hour I noticed the shifts in the gears were changing... It'd shift into second way too early if it was under some acceleration, and now, when completely floored, before the gearbox shifts into second it hits the revlimiter a couple of times.
    What the hell happened? There were no C/E codes, the light's off, the engine's running smoothly, but the gearbox seems odd.
    VN Executive S1
    Nov 2008
    No fluid.
    Called the guy who did it, has a new transmission for me.
    Cheers.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    VN Exec
    Dec 2008
    Quote Originally Posted by VRSLT323 View Post
    dirty fuel filter?
    mayb check the transmission fluid...
    Uhmm JimmyH has already said the guy who put the engine/gbox in didn't put transmission fluid in it and its buy replaced..
  1. VP Gearbox issues
    By timbra_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2009, 09:41 AM
  2. Gearbox issues
    By tri501 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2009, 05:22 PM
  3. Gearbox issues
    By Crummydore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2008, 05:29 PM
  4. Issues with new gearbox
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 04:56 PM
  5. New gearbox issues
    Last Post: 19-09-2007, 01:22 PM
