Results 1 to 6 of 6
Thread: Calais Dash not the same question
    VT V6 twin Turbo
    Feb 2005
    Newcastle region
    Default Calais Dash not the same question
    WIll a calais dash work in a vn exec without the calais loom i only mean the speedo tacho temp and fuel gauges
    vinnywelsh's Avatar
    vinnywelsh is offline Bored Technician
    VN V6 3.8L Berlina
    Aug 2004
    yeap, it should do. except yours is an exec so it may be different. i think the execs used the cable system for the speedo but the "berlina - calais" used the electronic method..
    just pull your old one out and have a look around and see if all the points will match up, but wait for someone to reply who definitely knows what will happen if you drop the calais cluster in.
    VT V6 twin Turbo
    Feb 2005
    Newcastle region
    94 vr 5sp, 04 vz wagon,82 vh V6 wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I think it will as the early vns had a loom that suited all dashes and it was a plug in and play thing but they then changed to the two different looms to save dough .If you look in the vn manual for wiring it shows the complete level 3 type dash setup wiring with the connectors taped back where they weren't needed.
    On the back of the dashes there is a terminal layout and what their functions are if your original dash and the calais dash terminals have the same functions it will be ok.
    Not sure how the audible alarm is affected though.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    mixin is offline Ol' fart, young heart!
    May 2004
    Country Vic
    Quote Originally Posted by markovr
    I think it will as the early vns had a loom that suited all dashes and it was a plug in and play thing but they then changed to the two different looms to save dough.
    Err, how "early" are these cars supposed to be?
    I have an '8/88 one (exec) in the barn, and it has no extra wiring in it. I can take photos to prove it all too!
    Nor have any of my customer's cars (early VNs) that I worked on from '88 to '95.
    It seems to be a bit of an urban legend lately about these execs running around with full calais wiring in them.
    I think where the confusion comes from is the VN HSV models got a different loom to suit the trip comp dash in base models (like the VN clubby) and some of these may have slipped out into other cars - but this would not have occurred until march 1989 onwards (after the V8 release).
    Early ones don't have the audible alarm, it was added as a running upgrade - just like climate, the change from cobra to mongoose alarms, deadlocking, changed solenoids for the locks, 3rd brake light..........
    The alarm & all these are all covered in Volume 10 of the Genuine VN Service Manual
    Nov 2003
    northside brisbane
    Sorry to generalise ...I was just going on what I have heard and the fact that in the diagram showing the vn wiring loom ( below), conn 4 ( the trip computer connector) is shown taped back....from that I could only assume some looms had this feature but not used.
    When I did the conversion to my vp I had to change some wires in connector 1 as the idiot light feeds weren't on the same terminals between the level 2 and 3 for idiot lights like check eng, brake fail , l/h indicator and press remote .
  1. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 06:35 PM
  2. Dash Cluster Question
    By fitzy2005 in forum General
    Last Post: 29-08-2006, 07:13 AM
  3. VP Lvl 2 Dash Tacho Question...
    By fazz1977 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 11:19 AM
  4. Dash colours question
    By greenfoam in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-12-2005, 08:56 AM
  5. Not another VN Calais dash question!
    By Lexx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2005, 09:50 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
