any idea why this would be happening? blows at twice the amp fuse as well. changed the wiring loom from vq series one to vq series two with bcm and never had problems before. removed the indicator switch and still blew.
Did the problem occur immediately after you changed looms? If not, I would suggest water in a globe or something similar.
The 1972 HQ Kingswood
yer straight after i changed the looms this problem occured. thought it was the dash switch blocks but i changed them to vq series two black ones and still burning out me fuses
All I can think is that the S2 stato loom has wires for indicators in the quarter panels, and perhaps they're shorting out onto something if not being used?
hmm didnt think of that, yer maybe its shorting out on metal some where i will have a looky tomorro
Your best bet is probably to stick globes in them, and tie them back in the quarter panel somewhere![]()
