Results 1 to 4 of 4
Thread: Radiator core leakage
    Brin's Avatar
    Brin is offline GOT MANG?
    VN Berlina, VR Exec & VC Vacationer LE
    Sep 2008
    Green Valley, NSW
    Default Radiator core leakage
    Hey guys
    I had to have my radiator replaced today as my radiator core was leaking and making the car overheat... I was just wondering, what would cause the core to leak?? The radiator, second hand, was put in only a few months back, spankin condition and wasn't leaking at the time. Rust or corrosion can be ruled out cause I have always kept the coolant at the right levels and used the right type also.
    Any ideas??
    VT Calais 3.8
    Nov 2008
    Depends where the leak was i guess.... do you still have the leaky old one sitting around? If you do look for dried deposits or drip marks from where the leak was, that may give you an idea of the problem...
    Morton's Avatar
    Fairstar the Funship
    May 2006
    From the central core? Or from the side tanks? The tanks are plastic and split easily.
    The 1972 HQ Kingswood
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Well there were rust marks on the centre of the radiator which tells me the centre core was leaking also... But the side closest to the battery was ****ing out ****house on the sides.
    Ah well. I have a new radiator now and dayyyyyyyyyyyum its the shiniest thing in my bay!!!
  1. Leakage between Y pipe and trans pan....
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 07:02 PM
  2. VS Leakage
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2006, 10:02 PM
  3. leakage
    By dave.b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2006, 11:09 AM
  4. Leakage
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2004, 02:07 PM
  5. Coolant Leakage
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2004, 10:42 AM
