Results 1 to 5 of 5
Thread: Gears slipping. NEED HELP.
    vp berlina(v6), vs statesman(v8)
    Dec 2008
    Exclamation Gears slipping. NEED HELP.
    Hey. my question will be simple for people that know abit about vn transmission. (auto)
    When i flog it between gears, insted of just changing they rev inbetween.
    Hmm anyone that cab help please? I guess i could also ask a mechanic lol. but i thought id let you pros help me out thanks
    VT
    Apr 2005
    QLD
    So the revs flare then change into the next gear or it doesn't change at all?
    Sounds like band tension to me.
    Dec 2008
    sorry for the late reply, forgot my password.
    Yeah it changes into the next gear.. just high revs into gear.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    maybe check your gearbox oil level 1st - if thats ok then u may have more serious problems
    NO CAR ATM.. -.-
    Jul 2006
    check oil levels, and the accelerator cable thats on the TB try adjusting it make it abit tighter than it is, or less if it kicks back to bad, but do the oil thing first
    servicing it would fix it (maybe)
    mine was so bad too would slip and take time changing gears, reasons were...
    not enough oil/too much oil
    tb cable to tight or to loose!
    but in the end its perfect again..i put it through hell but my auto never dies? LoL
  1. Car wont change gears, holds gears, and rough changes
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 06:35 PM
  2. vs 1996 slipping gears on auto
    By andymilne21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 07:38 PM
  3. slipping box :(
    By incarsolutions in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2008, 09:28 PM
  4. Automatic Gears Slipping
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2006, 12:08 AM
  5. VN Gearbox Slipping
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2006, 07:00 PM
Tags for this Thread
